11-26-2010, 11:23 AM | #1 |
Asks alot of questions
I'm needing some help...
It's about 30 degrees out right now, I go to crank up my truck and after pumping it furiously as I always do in the cold, it fires up.....however......it is screaming like the pedal is to the metal and I can't get it to stop. The throttle cable isn't stuck, nor the pedal. What could be causing this?
MY STABLE: '66 C10 LWB turning it into a shortbed stepside '77 LWB (my daily driver).....oh its a FORD ahhhhh! '07 MAZDA 3 (the wife's ride) |
11-26-2010, 11:38 AM | #2 |
Happy to be here
Re: I'm needing some help...
Check the choke or sticking butterflies.
11-26-2010, 11:46 AM | #3 |
Bingo! Choke was stuck. Thanks!
11-26-2010, 12:37 PM | #4 |
Happy to be here
U R Welcome...
11-26-2010, 01:26 PM | #5 |
Ya know, if the choke and everything is set up right, it should take one pump of the pedal to set the choke, turn the key, and you're running at high idle. I have no choke right now, so I have to pump several times... might wanna consider some adjustments.
