Old 12-06-2010, 02:41 PM   #1
coop34
Heater Hose Routing Help
After reading on here it looks like the top (outlet) of the heater core goes to the water pump and the bottom (inlet) goes to the intake.
My problem is most of the pics that I see show the heater hose going to the front of the intake and my port is on the back. Does anyone have advice on routing or pics of a similar setup. I have a 70 chevy with a swapped 350 from a 90 chevy.
Thanks!
coop34 is offline   Reply With Quote
Old 12-06-2010, 09:33 PM   #2
coop34
Re: Heater Hose Routing Help
tt For the evening crowd.
Old 12-06-2010, 10:37 PM   #3
swamp rat
swamp rat's Avatar
What kind of manafold do you have? the water port is on the back of the manafold?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-06-2010, 10:46 PM   #4
coop34
Yes, it's on the back. Not sure what kind. It's with a tbi setup.
Old 12-06-2010, 11:11 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
You want the hottest water available to go in the bottom of the heater core. If your intake only has a provision in the back than thats it.
The top going to the water pump is a secondary hookup as the original radiator had a port for the return line.
Hope this helps.....
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-07-2010, 02:44 PM   #6
Zeke's Garage
Zeke's Garage's Avatar
I'm intrigued by this...is there a reason for it? I've never really paid much attention to which side of the core went to which outlet/inlet on the engine/radiator.
Zeke's Garage is offline   Reply With Quote
Old 12-07-2010, 11:22 PM   #7
swamp rat
swamp rat's Avatar
The theory is that the heater core fills from the bottom and in doing so purges all the air out of the heating core allowing it to heat to full potential.
I have also found a number of trucks including mine that are the exact opposet, the reason i say this is that the heater core has 2 different hose sizes, a 5/8's and a 3/4. Per everything i have read the 3/4 is the return and the 5/8's is the inlet. On my truck i have a 3/4 return port on the bottom of the core, and my truck has a radiator return which is also 3/4. I have looked at a bunch of photo's and have found this frequently. My truck does heat up so i don't know if it really matters.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
