05-02-2011, 09:43 PM | #1 |
Got a problem and need help please?
I got a 1980 Chevy pickup that will not stay running, every time i prime it,it fires right up but immediately dies.What could it be? please help
05-02-2011, 10:21 PM | #2 |
Re: Got a problem and need help please?
Check the fuel pump first. go with a new fuel filter too.
05-02-2011, 11:02 PM | #3 |
x2 on the fuel pump and filter. As cheap as they are, that would be your most cost effective first option and a very likely culprit.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
05-03-2011, 07:56 AM | #4 |
Do you know it has gas? May seem like a dumb question, but with dual tanks, old gauges and sending units, water in the tank, etc.... I have "repaired" a few over the years with a gallon of gas when the owner thought there was gas in it.
Randy Summers Never brake in the learning curve! 1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737 |
05-03-2011, 08:22 AM | #5 |
GM Parts Guy
Is the choke working?
1975 Chevrolet C-10 Custom Deluxe (DD/WIP) 1989 Chevrolet C1500 reg cab stepside (Winter Truck) 1977 Harley Davidson XLH 1000 (Summer Cruiser) |
05-03-2011, 09:04 AM | #6 |
Robert Olson Transport
the fuel filter on these things goes for about $3.. id replace that..I would crank the motor while the fuel line is disconnected and see if you have fuel coming up from the pump. Assuming you have decent fuel coming and a new gas filter then the next step is to see if the choke is properly working.... after that youre looking at the carbuerator itself
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
05-03-2011, 11:01 AM | #7 |
If your priming it to get it to start, that only means one problem, your not getting any fuel into the cyclinders. Like it was discribed above, there could be a few different reasons why, do the simple stuff first, crack the line at the output of the fuel pump to see if your getting fuel to that point, if so, move up the line toward the carb, if not, then you need to find out why there is no fuel reaching the fuel pump.
There are a number of reasons for this to happen: 1) out of gas 2) clogged fuel line 3) clogged fuel filter 4) failed fuel pump 5) intake screen at the carb is clogged 6) neddle valve in the float bowl is stuck. |
05-03-2011, 11:36 AM | #8 |
GoatLube Experss
if it's above 50 or 60 deg's and it's get'n fuel, you dont even need the choke. first question, how long has it been since this truck run ?
like most said it sound's like the fuel pump. take the air filter off and pump the throttle with your hand, can you see any fuel squirt down the carb ? no=fuel pump yes=bad fuel/water be care prime'n it, I've seen poeple get burn'd or set the car on fire !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
