Old 02-06-2023, 02:31 AM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
What's the problem ?
A front suspension rebuild on my truck was just completed. Everything was replaced and the original control arms were used with the stock original front springs and a McGaughy 2 1/2 inch dropped spindle was installed. I am okay with the front height with the dropped spindle installed. A set of McGaughy 4 inch drop rear coil springs with shock relocators were installed as well. So in esssence I did a 2 1/2 - 4 inch drop which should have leveled out the truck which is the stance I want. As you can see in the picture, truck on hoist, the rear seem to be sagging too low. Now my truck didn't lead a hard life and now I look at the pics sat pretty level before the suspension changes. The truck came from the factory with the G50 Heavy Duty Spring option and the original springs are still in great condition. Any ideas or suggestions are appreciated. Thinkin' maybe shouldn't have taken it down so far ??
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-06-2023, 09:31 AM   #2
cadillac_al
Re: What's the problem ?
Agreed, I like the first pic
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 02-06-2023, 12:26 PM   #3
SCOTI
SCOTI's Avatar
Looks fine to me. We really need a better 'after' image vs the lift being in the way.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-14-2023, 12:52 PM   #4
biketopia
Also drive it some to let the front settle in. Were the control arms tightened up with the weight of the truck on them or at full droop while up on the lift?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 02-14-2023, 03:12 PM   #5
SCOTI
SCOTI's Avatar
Good points to verify.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-15-2023, 01:00 PM   #6
hewittca
hewittca's Avatar
Agreed, we definitely need some clearer phots. However, I think the truck looks more level after than before. The rear arches on these trucks are lower than the fronts, so when the chassis is level it actually looks like the rear is squatting a bit. On my truck, I set it up so the fender arch to ground distance is the same so the truck effectively has a 2" rake on the chassis.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
