06-27-2011, 11:45 PM | #1 |
Cooling Problem
I have a 95 5.7. Had a leak in the cooling system and felt it was in the radiator. Long story short: I bought a used radiator from what I thought was another 95 5.7. However when I went to swap it out, the hard lines on the passenger side facing the engine compartment would not fit. The connectors on the "new" radiator are too big.
Is there a way to swap the connectors? Am I screwed (pun intended) and I have to get another radiator? Thanks for the help, Mal |
06-28-2011, 05:48 AM | #2 |
Re: Cooling Problem
I believe there are adapters that allow them to work. When I got my new one, it came with them. Don't know much else about them. Perhaps you can contact a radiator company like BeCool to find out more.
06-28-2011, 08:55 AM | #3 |
Re: Cooling Problem
Thanks speedy. I'll look into that.
Mal |
06-28-2011, 07:02 PM | #4 |
Re: Cooling Problem
Ok, just in case there are others out there whose specialty has nothing to do with automobiles.
The guy at the auto parts store showed me I could take the connectors from one radiator and screw it into the connectors for the other radiator thereby making an adapter for my transmission cooling lines. Felt a little stupid but happy it was a simple fix. Mal |
06-30-2011, 12:15 AM | #5 | |
Chevys Kick A$$
Re: Cooling Problem
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
