12-25-2023, 12:59 AM | #1 |
Door grazing fender when opening
What would be my easiest solution to trying to make the door gap just a hair wider?
Just noticed it grazes the fender when I open it. Thought I’d ask before I likely make it harder than it has to be Thanks |
12-25-2023, 02:38 AM | #2 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Re: Door grazing fender when opening
I know there's some adjustments on the door hinges, but maybe the cab mounts are shot.
12-25-2023, 03:51 AM | #3 |
How's the gap at the back of the door?? If it's ok, the fender needs to go forward a bit. If the gap is wide, move the door back a bit.. All the restorers "shoot" for 3/16" gap.. All you need is about 1/8" more clearance.. The fender is bolted solidly to the cab, so cab mounts don't effect that gap..
12-25-2023, 08:23 AM | #4 |
That's a fairly easy adjustment. The cowl panel will need to be loosened. Once you get the fender where you want it, then also adjust the cowl panel to share the same gap to the door as the fender.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
12-25-2023, 08:44 AM | #5 |
From this picture it looks like it's the fender needs to forward. As mentioned, if other door gaps like good then fender for sure
12-25-2023, 09:48 AM | #6 |
Okay, great. So take the coke off and loosen the fender bolts in there and push the fender forward a hair and re-tighten?
12-25-2023, 10:50 AM | #7 |
You will want to loosen two top fender to cowl bolts, one rocker extension tab to fender bolt, and the large rear inner fender skirt to floor brace bolt, and gently move forward to achieve the desired gap. Then tighten all bolts.
12-25-2023, 11:20 AM | #8 |
Thanks for the guidance. Removed the cowl this am and got that fender forward a hair. Doesn’t hit anymore.
Merry Christmas |
12-25-2023, 11:32 AM | #9 |
Merry Christmas |
12-25-2023, 12:52 PM | #10 |
Much improved! Looks fantastic.
Merry Christmas!
12-26-2023, 07:29 PM | #11 |
rubbing fixed and looks far better!
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass * * * New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus! |
12-26-2023, 08:00 PM | #12 |
Perfecto!
12-27-2023, 01:02 PM | #13 |
Proprietor of Dale's Corner
Nice job!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
