Old 11-30-2011, 11:58 AM   #1
3QTRTONS
3QTRTONS's Avatar
Possible to make my '85 K5 into a '74?
I just scored doors, top, and windshield top section of a '74 K5. (Already got a '74 nose clip)What do I NEED to know to pull off transforming my '85. My guess is there's gonna be SOMETHING that'll 'ball it up'....
Thanks in advance
1994 C1500 rclb 1988 C1500 rclb
1969 ES5500 B E A S T 1983 C10 'farm truck'
1976 K20 Suburban 1984 K10 Suburban
1981 Jeep CJ5/350 Vortec
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 11-30-2011, 02:23 PM   #2
Berg
Re: Possible to make my '85 K5 into a '74?
Since you got the nose already done there are still some outside differences. The aluminum panel on the tailgate is different and so is the lettering if you didn't have the panel. Emblems are different and you could always get the factory aluminum molding for the 2 tone paint scheme to finish it off. I assume you already changed the front bumper with the nose swap so you may as well swap the rear bumper to the 73-80 style. I'd leave the fact that the 85 has a fuel door instead of the cap in the side of the quarter panel. For the interior, the console and dash pad and bezels are different and I think the early K5's used low back bucket seats. The Legal end of things could be different in your state. You may have to retain your shoulder straps for your seat belts and run a roll bar to affix the top tab to. Of course the inner floor structure is different but I wouldn't go crazy changing the carpet from cut pile to loop pile or anything like that. I think that stuff would be a good start.
1970 Chevelle SS396
1984 K5 Blazer -First Truck!
1999 Big Block K2500 'Burb
Berg is offline   Reply With Quote
Old 11-30-2011, 02:28 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Pretty sure the full convertible K5's had extra stiffeners in the rocker and possibly floor pan, to help compensate for no roof strength.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-30-2011, 07:22 PM   #4
3QTRTONS
3QTRTONS's Avatar
I got the Roll bar too... I'm not against attaching some stiffeners to the underside to make it right. Not everything has to be Factory or OE though.I have this K5 registered as an "Antique Vehicle" which means it is exempt from the otherwise mandatory annual State Inspection here. There isn't any Emissions Testing involved, either.
Old 11-30-2011, 08:15 PM   #5
RandyP
RandyP's Avatar
Nothing else really comes to mind on it. Other than the windshield posts/header, doors, top and then the issue with the tops of the quarters/bedsides.... that's about it I think.
Old 11-30-2011, 08:42 PM   #6
3QTRTONS
3QTRTONS's Avatar
What do I need to look out for with the quarters & bedsides?
Old 12-01-2011, 08:04 PM   #7
Jonboy
Slots go on anything!
The top on your '84 has a built in roll bar in it. It is a bugger to cut through. You will have to make some caps for the tops of the quarters, too. The 73-5's also have thick steel rocker boxes to keep the truck from flexing, especially with the roof off. You will NEED to do some kind of bracing to the rocker panels, or the body will flex. I had a cut down '77, and you could see the flex between the doors and quarters when driving on pavement. I could only imagine what would happen to it off road without soem bracing.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
