Old 10-17-2012, 06:13 PM   #1
JGross
To overhaul or not
I just bought a 5.3 with 87,000 miles on it. I'll be putting it in my 65 C10 and my origional plan was to overhaul it first, but 87K is not alot for these engines so now i'm not sure. What do you think?
JGross is offline   Reply With Quote
Old 10-17-2012, 07:23 PM   #2
clinebarger
Re: To overhaul or not
Run it!!!!!
clinebarger is offline   Reply With Quote
Old 10-17-2012, 07:31 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Unless you plan on doing a bunch of high performance stuff or forced induction etc, you can go ahead and run it as is. (heck, some folks throw turbo's on 100k junkyard motors).
With 87k I'd give it a once over for obvious defects, and throw in a timing chain and oil pump (assuming you'll have to pull the pan anyway to switch it for clearance). Thats like $180 worth of parts and the engines' good for another 90k at least
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-17-2012, 08:11 PM   #4
Indian113
Indian113's Avatar
When I bought my 5.3 I'd have been happy with a 87,000 mile motor-mine was a low mile(84,000)
Indian113 is offline   Reply With Quote
Old 10-17-2012, 10:20 PM   #5
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
many stories of these motors going, 200k, 250k, and more....unless the pan/valve covers/etc show lack of maintenance...just slap it in and go!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 10-18-2012, 12:21 AM   #6
crazy longhorn
Fabricate till you "puke"
Hell, its just a pup! I have a 5.3 , with 132,000 on the clock(good runnner), for my swap? I figure that I will open her up, & do timing chain/pump & valves springs, before she goes. 87,000 miles.....just run it! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-18-2012, 08:14 AM   #7
whitels1
whitels1's Avatar
While you have it out and on the stand it wouldn't hut to install a new timing chain, oil pump and pull the cam for inspection. I would say if all the lobes on the cam look good, go for it. It's alot of work to have to pull it again.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 10-18-2012, 10:08 AM   #8
Wasted Income
Boosted Member
Wasted Income's Avatar
I agree....RUN IT!
If your machine shops there are like they are here....you will probably be deeper into it to have it disassembled, cleaned and reassembled than you paid for the engine.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 10-18-2012, 11:13 AM   #9
Clyde65
Clyde65's Avatar
I would definitely run it, my BIL had a 2002 4x4 Silverado with 285,000 miles on it and it was still running great when he traded it for a 2010. He drove it like he stole it and all he ever did was straight maintenance.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-18-2012, 12:01 PM   #10
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I bought my 5.3 with 120K, opened it up and it "looked" well taken care of. Haven't run it yet, but had two LS guys look at it while I had the covers off and said it is a good motor. My pops had one with about the same mileage, he put in a 69 vette and hasn't had any issues... RUN IT! After changing oil pump, timing chain... and cam if you want an upgrade.
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
