Old 06-16-2014, 10:48 PM   #1
Mikem_72
'70 Stepside Build
Gem I found hiding in Huntsville, Texas
Mikem_72 is offline   Reply With Quote
Old 06-16-2014, 11:10 PM   #2
Mikem_72
Re: '70 Stepside Build
Update: Got it home and really considered keeping the original inline 6 but decided to pull it and go with a 350 for now.
Old 06-17-2014, 09:16 AM   #3
Mikem_72
Update:Been making some progress, trying to get it on the road
Old 06-17-2014, 09:19 AM   #4
Mikem_72
Update:
Old 06-17-2014, 09:37 AM   #5
Mikem_72
Update: Front suspension done with 2" drop spindle. Going with a 2/4 drop for now to get it going. Bags in the near future.
Old 06-17-2014, 09:41 AM   #6
Mikem_72
Update: Got the 350 done and mounted in the truck.
Old 06-17-2014, 09:45 AM   #7
flashed
That is looking good .
flashed is offline   Reply With Quote
Old 06-17-2014, 09:43 PM   #8
sduckworth13
sduckworth13's Avatar
Nice work, your truck is coming along great!
Scott
sduckworth13 is offline   Reply With Quote
Old 06-18-2014, 05:09 AM   #9
GSFMECH
On the road
GSFMECH's Avatar
I love the truck, it's coming along nicely, I have one the exact same color but yours is in better shape than mine. Stay at it, it'll be a sweet ride.
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 06-19-2014, 09:50 AM   #10
Mikem_72
Thanks man
Old 06-19-2014, 09:51 AM   #11
Mikem_72
Thank you
Old 06-19-2014, 09:52 AM   #12
Mikem_72
Thanks man, yeah Im trying not to let up.
Old 06-19-2014, 09:55 AM   #13
Mikem_72
Ended up getting a Demon 850 double pumper from my neighbor and some other engine parts that he had laying around. Hopefully its not to much carb for the motor
Old 06-19-2014, 11:06 AM   #14
thelonerife
thelonerife's Avatar
Looks great
thelonerife is offline   Reply With Quote
Old 06-19-2014, 09:59 PM   #15
70shortstep
Registerd User
70shortstep's Avatar
Looks good
John
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=613398
70shortstep is offline   Reply With Quote
Old 08-01-2014, 09:09 AM   #16
Mikem_72
Its been a while since Ive posted some updates, I live in Texas and its almost at the point where its too hot to even attempt to do anything outside in this heat. Ive got the front end bolted back up and some work done to the bed. Slowly but surely its coming along.
Old 12-26-2014, 02:37 PM   #17
Mikem_72
Update: Got the truck running and got some 5 lug steel wheels put on. Think I need to go lower.
Old 12-26-2014, 03:20 PM   #18
flashed
I think it looks good .
Old 12-26-2014, 03:46 PM   #19
dmw319
love the truck! good work
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 12-26-2014, 08:05 PM   #20
FL71C10
Looks good!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 02-19-2015, 10:12 AM   #21
Mikem_72
Got the mufflers installed last week. Went with some Flowmaster 40 series. Sounds pretty good but it needs more lope. I guess its time for a different cam.
Old 04-11-2015, 08:00 PM   #22
knomadd
knomadd's Avatar
The truck's looking good. You need to post some new pics with the white wheels and new tires.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 04-12-2015, 09:31 PM   #23
Mikem_72
It's been a while since I've given any updates. I've been driving the truck a lot more lately and working out all of the little bugs. I've repainted my wheels and put new tires on it and scored some hubcaps off of craigslist for $20 bucks. Here are some pics from this past weekends car show.
Old 10-02-2015, 08:18 AM   #24
Mikem_72
Its been a while since I've posted any updates and I've made a couple changes. So I was running a 350/350 setup and it was good and all but I just didn't like the 3 speed high rpms the transmission was giving me so I decided to go with a 700r4. I had a 350 bored over .030 in my garage that I had been working on and decided since I was going to change the transmission I might as well get the rebuilt motor ready and dropped in at the same time. These are before and after pictures of the motor. I went with some flat head pistons, Crane cam and lifters, and had the heads rebuilt by a coworker with all new seals, rods, and rockers all out of Summit.
Old 10-02-2015, 08:38 AM   #25
Mikem_72
I ordered a TCI lockup kit out of Jegs to rewire the 700 so the converter would lockup under vacuum. The wiring was pretty simple and the kit came with everything I needed. I also went ahead and mounted a temp sender (not pictured) to the side test port so I could monitor what temp I was running at. I also had to buy an adapter for the throttle on my carb so the TV cable on the tranny would have the correct geometry of pull, without this the shifting would be completely off and would end up burning up the transmission.
bucket, dropped, patina, rat truck, static
