Old 01-24-2013, 01:04 PM   #1
chris1htx
1984 Chevy C10 Gauges
Hello all,
I have a 1984 Chevy C10. The speedometer and gas gauges tend to jump around every time I hit a bump in the road. Is this normal for these older trucks? Can I do something for the gauges to stop bouncing around? Any insight will be great, thanks!
chris1htx is offline   Reply With Quote
Old 01-24-2013, 01:38 PM   #2
Pulse_GTO
Re: 1984 Chevy C10 Gauges
Mine shows different levels depending on if I'm accelerating or slowing down.
Pulse_GTO is offline   Reply With Quote
Old 01-24-2013, 09:57 PM   #3
cdm10700
cdm10700's Avatar
my speedo used to bounce around but hasnt since i put new cable on
the gas gauge i would check wires, probly one getin pinched between floor an frame or something like that
cdm10700 is offline   Reply With Quote
Old 01-24-2013, 10:15 PM   #4
rollin thunder
rollin thunder's Avatar
I have an 84 c10 and it did this as well got a new speedo cable and had a bad ground wire and a bad wire from sending unit and was touching bare wire to metal and was getting pinched in a couple different places. just replaced wires and all good
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 01-24-2013, 10:16 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
I had read about the bouncy gas gauge
heard it was because of aftermarket "Spectra" parts
I could read that name on my tank
assumed this was why my 78 gas gauge bounced with idiots
I added a ground behind the cluster where they go too one,didn't help
i bought and changed to a tach/gauge setup
had to rewire it and had to add a seperate ground for the gauge
and the bounce went away....
this past summer my 79 tank/sender rusted out
replaced it with "spectra" parts
as my auto parts guy said he's never heard of this prob
no bounce
speedo make sure it's in tight
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 01-24-2013, 11:46 PM   #6
chris1htx
That will be the first thing I'll check. Hopefully that's the problem, thanks guys!
c10, gauges
