06-08-2013, 09:08 AM | #1 |
Check Engine Light??
Searchy not revealing much..... On your swaps with modern engine, Where are you guys putting the Check Engine Light???
06-08-2013, 11:07 AM | #2 |
Re: Check Engine Light??
I threatened one of my customers that I was going to put a check engine horn in his conversion. I opted for bright under dash lights instead.
06-08-2013, 12:11 PM | #3 |
The worst would be the low air pressure buzzer out of a sterling semi truck. Ear splitting would be an accurate description.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
06-08-2013, 04:37 PM | #4 |
I put mine in the "Brake" light at the bottom of the fuel gauge.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
06-08-2013, 04:55 PM | #5 |
I didn't bother with a light.
If it quits running correctly I'll plug in the scanner.
06-08-2013, 06:45 PM | #6 |
check Engine light..? mine don't have one....its got me.
06-08-2013, 07:49 PM | #7 |
06-08-2013, 10:35 PM | #8 |
I'd run it to the Brake warning light as mentioned, or isolate it with a diode and run it to the high beam warning light. At least with that, if you're driving down the road and the high beam light should turn on out of nowhere, you know pretty much what's being communicated.
Josh '70 Custom Camper / 20 |
06-08-2013, 10:47 PM | #9 |
I just didn't want to drill a whole in the cluster/bezel. So I used an existing space.
