350 Transmission shifting strong
I recently replaced the coolant lines for the transmission. Previous owner used the wrong type of line and they started leaking real bad.
I got that fixed. No leaks now and the truck is running real good. (knock,knock). So good that now if I accelerate from a stop and push on it pretty good the tires will chirp going into second and even a light chirp into third. It's shifting real smooth if I pull away normally and even when I push it hard its not a real hard shift. Goes into first nice and easy from park. I'm wondering if this is normal from a 350 SB / 350 turbo combo? Fluid levels look good too.
------ 65 Chevy C10 Fleetside |
![]() Join Date: Apr 2011
Re: 350 Transmission shifting strong
Sounds like you might have a shift kit in it.
It's Better With Nitro
Great to hear! Yes, transmission fluid leaks will affect line pressure and reduce transmission longevity.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Not sure about the shift kit.
Keep on Truckin!
