01-01-2014, 11:04 PM | #1 |
Can you put a sport bumper on a one ton?
My dually has a step bumper on it that doesn't look bad but I'd really like to put a sport rear bumper on it but I don't know if it will bolt up to my frame or if ill have to modify the brackets. Any info is appreciated.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
01-01-2014, 11:08 PM | #2 |
Re: Can you put a sport bumper on a one ton?
blazer brackets, modify as necessary
"DON'T TOUCH THE TRIM!!"-Early Kyler |
01-01-2014, 11:52 PM | #3 |
You sure?
I'm thinking it will take the pickup brackets, just like any other 1/2 or 3/4 ton pickup. The uniqueness of it being a dually is all forward of the rearmost part of the frame. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
01-02-2014, 09:59 AM | #4 |
Standard truck brackets is all it takes for the no hassle install. Blazer/burb brackets can work w/modifying.
01-02-2014, 10:22 AM | #5 |
Truck Brackets.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
01-02-2014, 10:29 AM | #6 |
Same brackets as 1/2-3/4 ton
Bolts on and looks good There are a set of brackets for 80.00 on the 73-87 parts board... You can buy the bumper (ask for a blazer /suburban) at any bumper shop or body shop supply |
01-02-2014, 12:14 PM | #7 |
Thanks guys, I didn't know if the frame was the same back there or not
