Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 12-08-2013, 06:42 PM   #1
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Msd 88862
I listed this back in 2010 for $100 when they were $130... but I think they've come down now.
Its a harness for connecting an MSD 6LS box (6012) to your OEM controlled LS2/LS3. My understanding of the application is....besides allowing you to modify your timing via the MSD w/o ecm control....it allows you to add things like a 2 step limiter. Might be a solution for those with LSx swaps that can't or don't want to get into the ecm control.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 12-09-2013, 04:38 PM   #2
68Stepbed
68Stepbed's Avatar
Re: Msd 88862
So this kit allows for timing controlled by the MSD and the air/fuel to be controlled by an ECM or other stand alone fuel delivery system?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-09-2013, 10:40 PM   #3
68GMCCustom
Re: Msd 88862
I never hooked it up......but as per my understanding of the application...yes.
This harness plugs into the coil packs and the MSD box....taking the timing over and running it thru something you can control (the 6LS) w/o being inside the pcm/ecm. And yes....leaving everything else under pcm/ecm control. If you can read the white sticker it says LS2 EFI to 6012 w/58 tooth....so its for genIV...LS2 was early genIV.
from Summit's description: These MSD 6LS Ignition harness allow you to easily connect the 6LS-2 to a factory EFI system to take advantage of timing adjustments and settings. MSD's 6LS extension harness allows you to reach the front-mounted cam sensor on an early (24-tooth trigger wheel) LS2 when installing a 6LS Ignition Controller. The 6LS-2 Controller allows you to map a timing advance curve with MSD's easy-to-use Pro-Data+ software.
Kurt -
Old 12-17-2013, 12:00 PM   #4
68GMCCustom
Re: Msd 88862
anybody? I'd do $75.
add a MSD 6LS and you can control your timing w/o a tuner/program...
Kurt -
Old 01-10-2014, 02:14 AM   #5
johnboyon20s
Re: Msd 88862
pm sent
johnboyon20s is offline   Reply With Quote
Old 01-10-2014, 01:34 PM   #6
68GMCCustom
Re: Msd 88862
Sold!
Kurt -
