Old 01-29-2014, 11:41 AM   #1
fscboss
965 gmc long bed wood
we need to replace the wood in the bed. does anyone have the wood sizes? we have replaced wood before in other trucks but always cut the wood. the wood is so bad that i can't even measure it. thanks for your help.
fscboss is offline   Reply With Quote
Old 01-29-2014, 12:14 PM   #2
pdxhall
pdxhall's Avatar
Re: 965 gmc long bed wood
Check the Mar-K web page, I think they are there.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 01-29-2014, 12:19 PM   #3
pdxhall
pdxhall's Avatar
I found it for you.
http://www.mar-k.com/Catalog/PDF/Ins...Dimensions.pdf
Sanity'66
Old 01-29-2014, 12:40 PM   #4
newbe351
Also GMC Paul's...
http://www.gmcpauls.com/47-72_BedWood_Info.htm
newbe351 is offline   Reply With Quote
Old 01-29-2014, 03:20 PM   #5
kieth
kieth's Avatar
Go to a commercial lumber yard and buy your pine wood their, lowes and home depot are 3 times higher. We bought the pine for my 66 for $55.00 then cut it to Mar-K dimensions and it worked like a charm......I did cheat a little, got to pick thru a new load of pine myself and cherry picked the best boards......Kieth
looked like this finished:
http://kieth.smugmug.com/Trucks/66-GMC/i-DZW9XDm
like this as we installed:
http://kieth.smugmug.com/Trucks/66-GMC/i-tLxvc8z
like this as we initially processed it and trimmed with table saw, and cut groves with dado blade:
http://kieth.smugmug.com/Trucks/66-GMC/i-ngvCcFt
we did have to modify the cuts later and make the grove deeper and wider to the outside of the board just to get some wiggle room.
laid it out before painting to check fit:
http://kieth.smugmug.com/Trucks/66-GMC/i-skgXcKr
kieth is offline   Reply With Quote
Old 01-29-2014, 03:25 PM   #6
jayoldschool
Moderator
I used the GMC Paul's dimensions, they were perfect.
jayoldschool is offline   Reply With Quote
Old 01-30-2014, 01:17 PM   #7
fscboss
thank you we learned alot.
