Old 01-14-2015, 01:15 PM   #1
rdauphinais
rdauphinais's Avatar
Lifting a dually opinions needed
Hi everyone, i have a 1986 gmc K3500 dually. I will be putting a flat bed on it, and wanted some opinions on lifting it.
Questions:
1. What spring size do i have? I'm assuming 56"
2. I can't find any lift kits for one ton trucks, will 3/4 ton lift kits work?
3. How much should i lift it?
4. Should i do a kit with rear springs? Or just blocks? Right now the rear springs are stacks of at least 9, with overloads. Pretty rough
5. What brand?
6. What else do i have to look out for? T-Case drop? Brake lines?
7. Should i keep it dually, or take the outside tires off? Can i do That?
8. What size tires? there are 235-85-16 on it now and that won't look to good lifted. I don't think.
I'm pretty much a newbie at lifting to be honest, and need any opinions i can get.
Any pictures are helpful.
None of this will be taking place right now, because the truck is outside under snow and it's too cold up here in N.H. right now. Also low on funds.
Thanks in advance,
Ryan
rdauphinais is offline   Reply With Quote
Old 01-14-2015, 01:53 PM   #2
Ziegelsteinfaust
Re: Lifting a dually opinions needed
Do you plan to work the truck?
My K20 is high enough for me to work, but I could swing a 2 inch lift.
I have 265/75/16's, but I wish I went 285/75/16 to fill out the wheel well a bit.
Ziegelsteinfaust is offline   Reply With Quote
Old 01-14-2015, 02:30 PM   #3
rdauphinais
I don't think so, but it's hard fr me to say, when you say work it, you mean haul heavy load?
Old 01-14-2015, 09:52 PM   #4
Mike C
Mike C's Avatar
I have an '86 k30 dually as well and have contemplated a lift. If I were to go that way, I think a shackle flip is the only thing I would consider. i would also look into relocating the overload pads so they hit the springs. On the front you would replace the leafs. I think 2 1/2" springs on the K30 gets you almost 4" relative to the K10/K20 trucks. Offroad Designs makes a shackle flip.
Mine has a J&I flatbed on it and I elected to leave mine stock height (at least for now...) since I pull a gooseneck with it around the farm.
My truck is a regular cab with 454, SM465 and NP205. I'm running Alcoa dually rims with 235 85 16 BFG AT's. I put a Spartan Locker in the Dana 60 front and a LockRight in the Dana 70. FWIW, it does awesome donuts....
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-15-2015, 12:29 AM   #5
Ziegelsteinfaust
I am 5'9" so a 2 inch lift is the highest I could comfortably lift a 100 pounds up too.
Working the truck is just using it to do what ever hobby you have or project you need to do.
Of course I see people lift trucks 6-8 inches, and use them for contracting work. It is thier back, but I wouldn't risk it.
Old 01-15-2015, 03:33 AM   #6
andrewmp6
Talk to http://offroaddesign.com/index.htm they have lifts for a 1 ton and they only deal with 73-87 trucks and own a few they are one of us.
