Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 01-21-2013, 01:09 AM   #1
SuperSub
SuperSub's Avatar
Purists Look Away... I'm Cutting the Dash!
I have been toiling over this decision for a while now but I have made up my mind. I have wanted to put a stereo in my ’67 Suburban, but I have very specific criteria for the options I want in the head unit. Some of those criteria include that it controls and charges my Iphone, it has Bluetooth phone and streaming capabilities and it has several RCA pre-outs to run all of the speakers that I am going to need in this land yacht.
After doing online research and visiting the local ‘Big Box’ store to fiddle with the stereos they have in stock, I came to the conclusion that I was going to have to use a newer ‘DIN’ style radio. I know, I know, there are companies who make older looking stereos with many of the features of newer units, but they don’t yet offer the Bluetooth phone and streaming capabilities I mentioned earlier. Also, I looked at these things up close and was less than impressed. Additionally, many people who have purchased them have given poor reviews online and stated that they are cheaply made. I considered mounting the stereo in an alternate location, but that would cause a series of other problems such as not being able to see the display, reaching the controls, as well as having to contend with buying a radio delete panel. NOPE! I’m cutting the dash.
I figured that if I am going to do this, I want it done right. I did some additional research in the forums and saw two basic outcomes when people have decided to cut their dashes to install stereos. The first outcome was the all too common hack job. You know what I am referring to… it appears as if they had their 8-year-old kid peel the dash back with a P-38 military surplus can opener. Uuuugh! I get the chills just picturing it. The second type of outcome that I saw was actually very clean and was accomplished by purchasing a billet aluminum bezel at about $80 a pop. I tried contacting several of the people in the forums that had sold them in the past, but no one returned my IM’s. Hmmmm, looks like I’m on my own.
After researching what the market currently has to offer, I found the Alpine CDE-136BT fit the bill. The fact that it got good reviews online and it was on sale clenched the deal. I decided that I might as well contribute a bit to the forums, as I am constantly using it as a resource. So, I will show you all how I went about doing this project.
First, identified and I bought the radio. Obviously, the newer ‘DIN’ style radios won’t fit in the stock 67-72 Chevy dash, but this photo was shown to illustrate that point.
I measured the dimensions of the radio (a couple of times) then made a template in order to make a bezel and to assist in cutting the proper size hole in the dash. I used a piece of cardstock so that it wouldn’t be too flimsy.
I found a piece of scrap aluminum that was approximately 1/8” thick. I used a machinist’s ruler and the template that I had already made to trace the correct dimensions onto the scrap aluminum. I then used a socket as a template to draw rounded corners on the scrap. I filed the rounded corners to match.
I used the drill press to drill a hole in the scrap, so that I could cut out the center portion (where the radio fits).
I used a pneumatic body saw to cut the center portion out. These saws are very inexpensive through Harbor Freight and they work fairly well.
After filing all of the edges smooth, I used a piece of Scotch Bright abrasive pad to give the bezel a uniform brushed look.
I used my template again, as well as my newly built bezel to determine how much of the dash needed to be cut out.
I used masking tape to mark where my cut would be. I used the pneumatic body saw to cut the steel dash panel.
I placed the bezel in place and slid the sheet metal radio-mounting sleeve through it. I then bent out the securing tabs on the sleeve, which held everything in place.
Next, I placed the stereo into the sleeve and wired it as necessary.
All in all, the fabrication and cutting of the dash took me about 3 hours. I was happy with the way that it came out and I didn’t have to spend the $80 bucks for the bezel. Hopefully soon I can get to installing the AC / heater and painting the ashtray.
SuperSub is offline   Reply With Quote
Old 01-21-2013, 02:29 PM   #2
zellway
zellway's Avatar
Re: Purists Look Away... I'm Cutting the Dash!
Just had to post this. Just for fun. Looks like a clean install. I could not do it to my Burb but it looks good how your doing it.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 01-21-2013, 02:49 PM   #3
youngrodder
youngrodder's Avatar
Nice work.
Very professional looking......
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-21-2013, 03:06 PM   #4
SuperSub
SuperSub's Avatar
Great graphic! Thanks for you post.
Old 01-21-2013, 03:07 PM   #5
SuperSub
SuperSub's Avatar
Originally Posted by youngrodder View Post
Nice work.
Marc
Greatly appreciated.
Old 01-21-2013, 04:41 PM   #6
SamMargritz00
SamMargritz00's Avatar
that looks great! I know there are some people that hate the newer radios in these classics but I believe that it's your car, do what you want to it. I cut out the whole dash and remade it for my double din install.
Blazer Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=483399
SamMargritz00 is offline   Reply With Quote
Old 01-21-2013, 05:30 PM   #7
SuperSub
SuperSub's Avatar
Thanks Sam.
J
Old 01-21-2013, 07:50 PM   #8
69GWC
Looks real good you did a nice job with it.
69GWC is offline   Reply With Quote
Old 01-21-2013, 10:52 PM   #9
Zane M
Looks great, you did a nice job.
Zane M is offline   Reply With Quote
Old 01-22-2013, 02:46 PM   #10
_Ogre
_Ogre's Avatar
looks good supersub.
i'm all for installing a single din stereo in the dash.
new single din head units will be around for years.
shop air compressor timer
Old 01-22-2013, 03:21 PM   #11
Lemield
Lemield's Avatar
Looks really nice. I cut the dash in all three of my trucks and I have not regretted it a bit. It is nice to have a modern radio with a USB port!
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 01-23-2013, 05:08 PM   #12
SuperSub
SuperSub's Avatar
Old 01-23-2013, 05:10 PM   #13
SuperSub
SuperSub's Avatar
I agree and you get to enjoy all the modern convieniences that modern stereo have to offer.
Old 01-23-2013, 05:12 PM   #14
SuperSub
SuperSub's Avatar
What is really cool is that I have now been streaming music, podcasts and cellphone calls wirelessly from my IPhone. It is super simple and works great!
Old 01-23-2013, 05:28 PM   #15
64fleetside
I cut mine too-I don't think we are going back to AM band anytime soon...
64fleetside is offline   Reply With Quote
Old 01-24-2013, 02:17 AM   #16
thelonerife
thelonerife's Avatar
Looks nice. I cut one of mine and used a plastic bezel that covered the indentions. I did order one of those 80 dollar aluminum bezels. Haven't used it yet.
heres pics of the one I did.
thelonerife is offline   Reply With Quote
Old 01-26-2013, 02:28 PM   #17
mrhino
Looks nice. Real classy
unlike my "hack job" btw I used Tin snips
mrhino is offline   Reply With Quote
Old 01-26-2013, 03:32 PM   #18
69GWC
Wow thats crazy..!
Old 01-27-2013, 02:19 AM   #19
thelonerife
I used a dremel tool. it works great.
I also cut holes for my a/c vents in my GMC
Old 01-27-2013, 05:44 PM   #20
SuperSub
SuperSub's Avatar
I like the precise cuts you get with a Dremmel tool, but I would have had to used about a dozen discs to get the job done. That gets a bit expen$ive. It would have also taken much longer to do.
Old 03-11-2013, 10:24 PM   #21
1985_C10
1985_C10's Avatar
Looks good. I am about to hack away at my dash to put a new radio in. I'm tired of hearing nothing but wind coming through my vent window as I'm driving.
1985_C10 is offline   Reply With Quote
Old 03-11-2013, 11:36 PM   #22
SuperSub
SuperSub's Avatar
I've had the opportunity to enjoy the new stereo for a while now and I'm not regretting my decision to cut the dash. If you want my 2 cents, plan out the project and take your time with the cutting. Then enjoy!
Old 03-13-2013, 11:50 PM   #23
1985_C10
1985_C10's Avatar
i was planning on taking my time because i dont want to have to find a new dash. lol
Old 03-14-2013, 02:41 PM   #24
SuperSub
SuperSub's Avatar
Well, I see that dash patch panels are available, but I sure the heck wouldn't want to have to weld one in.
Old 03-18-2013, 12:57 AM   #25
PAWS 72
PAWS 72's Avatar
Looks good and clean. Not a hack job like you see all the time.
What size socket did you use on the corner of the bezel.
PAWS 72 is offline   Reply With Quote
67 suburban din stereo
