Old 01-24-2015, 01:02 AM   #1
IdahoMan
Dash Pad Removal
Hi.
I'm trying to remove my dashpad.
It is stuck on the passenger side. I understand there are two "clips" under there on each side of the speaker-grate?
It isn't coming out, and if I use anymore force I believe the dashpad is going to break in half. Something has already broken and fallen on the floor (looks like a plastic screw with threading on each end) and I have heard other snaps.
Just what am I supposed to reach under and unscrew/disconnect before trying to pull it up and out?
Thank you.
IDahoMAn
IdahoMan is offline   Reply With Quote
Old 01-24-2015, 01:49 AM   #2
J Knight
J Knight's Avatar
Re: Dash Pad Removal
Did you pull the a/c ducts off and did you remove the screw on the right side close to the door jam.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-24-2015, 03:18 AM   #3
IdahoMan
I reached above the glovebox and disconnected the AC duct, yes.
There is no screw there on my truck.
Where it seems to be stuck is on each side of the right speaker grating at the base of the windsheild.
Old 01-24-2015, 09:07 PM   #4
IdahoMan
Anybody else???
Or do I need to break out the circular saw??
IM
Old 01-24-2015, 10:36 PM   #5
bnoon
What year do you have?
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 01-25-2015, 01:37 AM   #6
IdahoMan
Mine is an 81 Silverado.
I tried again to pull back on the dashpad with my left hand gripping the edge of the defrost-vent and my right lifting up slightly on the bottom edge below the emblem.
It doesn't budge. :S
Old 01-25-2015, 10:06 AM   #7
bnoon
When you have all of the screws out the edge under the emblem should raise up with no effort at all. You have the gauge bezel removed and (I think) 4 screws from the passenger's side bottom edge, plus one in each door jam?
Old 01-25-2015, 12:49 PM   #8
Gregski
Gregski's Avatar
sometimes the LMC Truck website / online catalog can be useful helpful for disassembly and or re assembly
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=75
Gregski is offline   Reply With Quote
dash, dashpad, pad, removal, remove
