Old 11-21-2019, 09:06 PM   #1
Brad54
Brad54's Avatar
Can you tell me what t-case and trans combo this is?
Cleaning up around here. Got this in a trade a while back, and don't need it.
I've got a '76 Dodge with a granny-4 and NP205, but I can't crawl under the truck to look at the case.
I've got a '62 K10 project with a divorced 205, but it's buried under shelves and I can't dig it out to compare.
I couldn't find a tag on it, either.
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 11-21-2019, 09:13 PM   #2
El Dorado Jim
Re: Can you tell me what t-case and trans combo this is?
it is a SM465 transmission with a NP205 transfer case, from a chevy truck
El Dorado Jim is offline   Reply With Quote
Old 11-21-2019, 09:45 PM   #3
kipps
+1. The most bullet-proof combo that you'll find anywhere.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 11-22-2019, 04:45 PM   #4
sweetk30
sweetk30's Avatar
same info but more .
1984 and older with mech clutch linkage . fig 8 t-case adapter with 10 spline output and input gear . the front output no flat flange makes it a mid70's and older if i recall the dates correct with 10spline output and fixed yoke .
good stuff or great parts doner stuff .
tag on the np205 t-case would be under the shift rails on the front of the case and 98% are covered in dry oil/dirt mix .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-23-2019, 02:01 AM   #5
Brad54
Brad54's Avatar
AWESOME! Thanks guys.
