04-19-2015, 02:08 PM | #1 |
89 s10 cab removal?
I am getting ready to remove the cab off my 89. Just want to check here to make sure I have the following disconnected.
Master brake lines brake pedal assembly and throttle cable parking brake cable steering column its an automatic so anything else I am forgetting? |
04-25-2015, 12:03 PM | #2 |
Re: 89 s10 cab removal?
Front wiring and engine wiring, I use to take them loose at the firewall where they go into the fuse box, it may require some of the gunk [sealer ] around the bulkhead block to be removed but once you do, you can take all of the wiring loose there. The big part pushs through like it would be going to the firewall after it is unplugged to separate the wires
