Old 05-17-2015, 11:50 PM   #1
ChevyTruckGuy68
Wheels
I recently put 16" factory style steel wheels on my 67 k20. I would assume they are 80's era. 3 the center to out section is rivited together and 1 is welded, so all are not completely identical. All the rims compared to the 16.5 factory ones I originally had are just a little to small to mount over the front drums, and have clearance for the drum to stretch, but come close to where the center section that is riveted/ welded meets the outer part of the rim. These tight tolerances keep the drums from flexing I assume, and is the cause death wobble only when I am braking. This wobble doesn't happen when I am using the 16.5's. I tried Spacing the 16" wheels away from the drum with some washers but they aren't enough, do to stud length.
Any recommendations???
Thanks,, Andrew
Andrew
ChevyTruckGuy68 is offline   Reply With Quote
