03-03-2015, 10:46 AM | #1 |
budget scan tool
i am the current owner of a 68 short step c10 4.8 sitting in it. / 91 gmc c1500/ 04 impala/ 05 saturn. i do not own a scan tool and what would your suggestions be? not totally opposed to harbor freight. would like to see sensors and clear codes.
03-03-2015, 12:16 PM | #2 |
Re: budget scan tool
I've been up close and personal to the Harbor Freight copy of the snap on Modus. It will do all you need and more, it just have the oscilloscope function like the snap on one. I realize it's a bit over 1g but with today's cars unless your ok with paying $100 to someone else(here) you need a decent scanner.
03-03-2015, 02:10 PM | #3 | |
http://www.harborfreight.com/catalog...t?q=scan+tools |
03-03-2015, 03:11 PM | #4 |
I have one of these.
http://www.scantool.net/scan-tools/p...5-compact.html It is simply a cable and a microprocesser that connects your OBD2 port to a laptop. Comes with software disk to load to look at data real time, log data and reset codes. About 25 dollars and much better than HF crap |
03-03-2015, 05:54 PM | #5 |
this sounds too cheap to be of much use http://www.ebay.com/itm/QZO-ELM327-U..._Tools&vxp=mtr
03-03-2015, 06:19 PM | #6 |
I have the bluetooth version of that ELM. I bought it off Amazon for less then $10.
It works. The software isn't the greatest but it works.
03-03-2015, 06:35 PM | #7 | |
the bluetooth to phone looks ok but it may not be enough. |
03-03-2015, 07:49 PM | #8 |
I also have one that connects the OBDII port to a laptop. It's got a lot of functions that a handheld scanner doesn't, like capturing real-time graphs and on-board diagnostic help. I think I paid about $50 for mine.
03-03-2015, 07:52 PM | #9 |
http://m.harborfreight.com/autel-max...tem-62385.html
Here's the copy of our modus that we checked over at the HF store in Minniapolis. It does almost everything our modus does at 1/6 the price. It can tell you the location of the faulty componants and tells you how to repair said componants. Now they were demoing the unit we tried and the store unit may or may not have all the programs but again,1/6 the cost of our Modus |
03-03-2015, 08:43 PM | #10 | |
03-04-2015, 01:06 AM | #11 |
Have any of you tried either of these ?
OBD Auto Doctor OBD Fusion Both will use the generic Bluetooth or WiFi ELM. I've been looking at these and they seem like they'd be better than the cheap generic scanners that don't show much. |
03-04-2015, 03:15 AM | #12 | |
A code reader would have told me the ABS and 4wd were malfunctioning in my 04 suburban but to narrow it down beyond that it would be useless. The Verus(yes we have 3 different snap on) was able to pull up the wave forms in a 3 layer graphic and even highlighted the odd signal from wheel Sensor 2 (POS Chinese bearing)that was causing all the problem. Without that knowledge how would you know the sensor was putting out more of a clipped wave than a smooth(btw bearing still ok)wave. We were able to drive back in the snow with 4wd and ABS using the data from sensor 1 to act as both sensors with the Verus help. That's an 04 truck that won't give you 4wd and screams every time the brake pedal is pushed that you need brake service. What's a 2013 or newer going to need in diagnostic scan tools? Any of our monthly payment snap on's will do it, my Accutron from 2004 will be as useless as it is now. |
03-04-2015, 05:33 PM | #13 |
What a simple ELM scanner will do-
Reads engine codes |
03-04-2015, 07:00 PM | #14 |
so what is being said is....?? spend $1000 get something very usefull, or spend almost nothing <$25 and get a "code reader" ??
03-04-2015, 10:07 PM | #15 |
I have this one....works great for me...does live data too....
http://www.harborfreight.com/can-obd...0693-9479.html |
03-04-2015, 10:11 PM | #16 |
IMHO code readers are ok for simpler pre 2000 vehicles and diagnostic scanners are almost neccessary for newer than that. Code reader will get you in the neighborhood where Diagnotic scanner gets you to the exact thing you need to repair and if you don't know how has illistraighted instructions for you.
We love taking the "Alpine Automotive" S10 down to O Reilly's for parts as invariably someone is there getting something scanned by the store Accutron and O Reilly's gives them a printout of all the possibilities it could be, which really confuses them and that person asks for more information and they point at me or Cory and say "ask them" That's the difference. If you can't afford diagnostic right now code reader is a sign to put you in the right direction which is better than being blind. Live Data is ok for timing and fuel trim issues but is not really impressive. Last edited by rickpilgrim; 03-04-2015 at 10:25 PM. |
03-05-2015, 09:44 AM | #17 |
I am paying attention to this thread, lot's of good information. (plus the snap-on guy would LOVE to sell me a scanner...) don't need one for the '86 (just $$), but I have run into times on the '03 where a scanner would have really helped.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
03-05-2015, 04:05 PM | #18 |
78K & 79C Jimmys
Almost bought one recently for the
05 Malibu 03 Grand Am 09 Vibe min quality I'd want started @200$ I'd want the ABS part too http://www.canadiantire.ca/en/pdp/au...l#.VPjf23wlnk0 http://www.canadiantire.ca/en/pdp/ob...l#.VPjgvHwlnk0 http://www.canadiantire.ca/en/pdp/ab...l#.VPjhMHwlnk0
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-05-2015, 04:38 PM | #19 |
Check out the brands launch and autel. They should have something that will work for you in your price range. I have used products from both and they work well. We have a modis at work and I hate the slow POS. Its a hassle to use. Will be looking into replacing it with something from launch in the near future. If you have a tablet there are many options to use it. Whether android or Ipad.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-05-2015, 09:54 PM | #20 |
"Check out the brands launch and autel"........
The Harbor Freight ones are actually Centech branded Autels..... |
03-06-2015, 02:25 AM | #21 |
Ours modus is the last yr of production and yes, it boots up a little slow if you don't leave it on standby but my over 50 yr old brain and fingers really don't find it hard to use, other than it isn't touch screen. We have ours rigged to a cart with a 42" monitor and a mouse. Verus is a whole different matter. Fast loading,touch screen and more capability than I may ever figure out. Of course updates are planed to 2022 or so we are told. OTC diagnostic is decent also. |
08-31-2015, 09:57 AM | #22 |
Who Me?
Who has used a bluetooth scan tool that will work on iphones? I see some of the better ones are on Android based phones.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
