Old 11-01-2015, 09:47 PM   #1
tjsblazer
tjsblazer's Avatar
Question Wireharness clips on the Frame question
Hey how many wireharness clips are on the Lh frame rail on a 72 Blazer? The ones that both the fuel sending and rear lighting wires clip in to.
Also, does anyone have pics of where they go. I can't seem to find a drawing in the Assembly manual.
Thanks. Jeff.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 11-02-2015, 01:28 AM   #2
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: Wireharness clips on the Frame question
There was 3 of them that I pulled off mine
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 11-02-2015, 12:47 PM   #3
Minnz
Minnz's Avatar
Here are a couple pics from mine:
72 Ochre Blazer
69 Camaro Z28 Garnet Red
48 Willys (rolled)
Minnz is offline   Reply With Quote
Old 11-02-2015, 12:53 PM   #4
Minnz
Minnz's Avatar
One more:
72 Ochre Blazer
48 Willys (rolled)
Old 11-02-2015, 01:41 PM   #5
hemi43
hemi43's Avatar
Not sure if these pics will help, but I took these before I took the frame apart.
Edit; Oops, I just realized it was wiring clips you were concerned about and not brake line clips. Those are the only pics I had, sorry.
hemi43 is online now   Reply With Quote
Old 11-02-2015, 06:48 PM   #6
jaros44sr
jaros44sr's Avatar
Maybe someone can actually find the page in the assembly manual, I can'y
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 11-02-2015, 07:18 PM   #7
tjsblazer
tjsblazer's Avatar
I actually had 7 total and 2 of them were along the rear x-member for the Fuel sending wire. That would leave 5 along the frame rail if I had them all.
Thanks. That helps with a few of them.
Yeah I took ones of that side for the hard lines but never thought to take any of the Rh side for wires before I pulled it apart. Thanks though.
I can't find a page with it. I thought I looked through the whole manual. Might give it another shot.
Hopefully someone chimes in who has a survivor truck that has the factory clips still in place.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-02-2015, 07:35 PM   #8
tjsblazer
tjsblazer's Avatar
Actually Minnz you've shown 4 different ones on your pics. Mine had 5 remaining along the side when I took it apart if that was all of them there is only one more spot. Don't know if my Bkazer still had them all or not.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-02-2015, 07:42 PM   #9
jaros44sr
jaros44sr's Avatar
is this it?
WIN_20151102_183756 by [url=https://www.flickr.com/photos/97391199@N06/]
It measures .575 from front of assembly manual
SAFETY FIRST
AS usual, off topic
Jim
Old 11-02-2015, 07:47 PM   #10
tjsblazer
tjsblazer's Avatar
is this it?
Jim. I'm not sure cause the 2wd x-member in that picture threw me for a loop but I is the only page I ever saw in the manual.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
Old 11-02-2015, 08:09 PM   #11
jaros44sr
jaros44sr's Avatar
Jeff, it says except for G&I-X
SAFETY FIRST
AS usual, off topic
Jim
Old 11-03-2015, 10:57 AM   #12
Minnz
Minnz's Avatar
Ok, I found another pic of a 5th clip. It was located above the driver's rear spring shackle:
72 Ochre Blazer
48 Willys (rolled)
Old 11-03-2015, 08:06 PM   #13
tjsblazer
tjsblazer's Avatar
Well that may be it. Like I said mine had 7 total with 2 being on the back x-member. Maybe 5 is correct for down the frame rail. My truck was fairly stock except for a 4"lift. I'm going to use your pictures Minnz as reference for now. Thank you.
Jeff.
'72 Blazer K5
My Blazer Build:
My Engine Build:
