11-16-2015, 01:16 AM | #1 |
12 Bolt Brake/Axle Mismatch
Hey guys, I have an issue with a '67 I picked up the other day. I've been slowly going through it to make sure it's going to be reliable 'till I get a chance to really get into it. The truck has been pieced together from a few other trucks.
I put wheels and tires on it the other day at Discount Tire and one of the lugs started spinning and wouldn't tighten. Cut it off today and when I pulled the drum to put the new stud in I saw it was only contacting part of the shoe. Step in the shoe liner, untouched half of drum(see pics). It's currently 5 lug. I'm guessing the PO stuck in some later longer axle shafts for the 5 lug. The axle flange sits pretty far away from the bearing. Need some input on where to go now. Should I be able to get the shorter ones...plug and play... or is there more involved? Lets not get into all the wrong body parts discussion, lol. Unless someone has some fenders and a radiator support in Colorado. Already have a hood. Any help would be apreciated |
11-16-2015, 08:38 PM | #2 |
Senior Car Nut
Re: 12 Bolt Brake/Axle Mismatch
someone put '71-'72 axles in the '67 housing most likely. axles got longer sometime in '67 IIRC and if your housing is early '67 the 5 bolt axles would be longer. '67 would have 6 bolt hubs, front and rear. they probably did the same for the front components. '67 would have drum brakes up front, '71-'72 would be discs. do you have discs up front?
you can buy new axles the correct length here's one thread http://67-72chevytrucks.com/vboard/s...06152&posted=1
Larry Last edited by fleetsidelarry; 11-16-2015 at 08:51 PM. |
11-16-2015, 09:29 PM | #3 |
Yes, the fronts are 5 lug also. That's what I figured. I was more curious if I could just get the shorter 5 lug shafts. Briefly looking around last night I saw that Summit has a "kit" for it. The kit comes with spider gears and drums for $500. I know I don't need the drums and I would assume I don't need the gears. I would think I just need to get some short 5 lug shafts. Any ideas?
11-16-2015, 09:53 PM | #4 |
Oh yeah, Thanks for the link. I searched but didn't see that one.
11-16-2015, 10:23 PM | #5 |
There is also a problem with the bearings are not riding on the proper hardened axle surface that it is suppose to ride on.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
11-16-2015, 11:01 PM | #6 |
67-72 parts collector,…
Your truck has a 67-68 grille, but the rest of the front clip is 69-72.
See how the headlights don't fit? What year truck is it suppose to be?
11-17-2015, 12:13 AM | #7 |
60-66 Nut
You do not need to change the spider gears along with the axles. The spider gears are required in the '63 & '64 12 bolts. The '65-'82 12 bolts already have 30 spline axles and spider gears. In late '70 the differential housing increased in width by 1.5".
11-17-2015, 08:00 AM | #8 |
Senior Car Nut
I was worried that I didn't remember the model-year change correctly, and I didn't. I was also hopeful that Captainfab would come along later and correct that in his usual non-critical fashion, which he did.
I know there are several sources for these axles, I just haven't had the need to remember them, but here's one, note that it does say that the axles are available separately: http://www.classicperform.com/Store/...k/6364RACK.htm
Larry |
11-17-2015, 02:05 PM | #9 | ||
"I ain't nobody, dork."
I am swapping everything 5 lug from a 1972 GMC frame over to a 1969 C10 frame which is all 6 lug. The 1972 Axle housing is wide, and the 1969 axle housing is narrow just like your 1967. So I bought conversion axles from Moser that are the correct shorter length for the 1969 housing, but have 5 lugs like I want to convert over to the 5 lug setup on the truck.
http://www.summitracing.com/parts/msr-a3065gmt5 Gary
11-17-2015, 03:29 PM | #10 |
Thanks everyone for the input. That's exactly what I thought. Just had to get some other opinions.
Lolife99....Notice the last part of the original post...I knew someone would go there. Haha. It is a 67 by the vin and the bed doesn't have markers. Although there's allot of 72 in it, I'm going with 67. |
