11-25-2015, 01:05 PM | #1 |
Tranny swap ?'s
currently have a h400 in my 1970 c10, mild 350 (cam intake carb headers exhaust) and I've been looking at a new TKS i believe is the brand name, th700 R4. will this bolt right up to my motor? anything challenging to expect as i plan on doing this myself. also thinking of doing a 2000-2400 rmp torque converter at the same time
11-25-2015, 01:06 PM | #2 |
Re: Tranny swap ?'s
also how much would a h400 with shift kit go for used? would like to get something out of it, its a great tranny and strong
11-25-2015, 01:17 PM | #3 | ||
"I ain't nobody, dork."
Re: Tranny swap ?'s
A TH700R4 will bolt directly to your SBC. I think the rear tranny mount will be the same too.
I'd think about 500 bucks for the TH400, if it's still in great condition. Gary
11-25-2015, 01:30 PM | #4 |
Its a Truck Thing......
Re: Tranny swap ?'s
You will have to change the driveshaft yokes as they are different between the 400 and 700R4. If you had a TH350 you would be fine or 3OTT, but would have to shorten the driveshaft depending on the tail length on the 350. You may have to shorten the shaft anyway. You also will need the metric TC bolts for the TC, buy them at a parts store. You will need an adapter for the TV Cable angle depending on what carb you have. 700R4's hate heat so I would add an additional cooler to the trans lines. How are you going to lock up the TC or are you? Speedo cable is another issue to tackle and you may have some issues depending on what rear gear you are going to run. I have done this so if you want exactly what I did I, please PM me and I will send you every part number I did for my swap. I run 3.42's with my 700's and everything works like GM designed it to do.
Let me know Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
11-25-2015, 01:45 PM | #5 | |
Re: Tranny swap ?'s
11-25-2015, 01:51 PM | #6 | |
Re: Tranny swap ?'s
Smitty
