Old 09-20-2003, 10:30 AM   #1
nosto
Flamin' Bass
nosto's Avatar
Seeking help/info on S-10 Blazer (transplant)
I know nothing about this model, but,
I have a chance to do a favor for a neighbor whose son trashed the engine in his '84 S-10 5-speed. I found a wrecked '89 auto, 4.3L in good running condition. I plan to transplant the engine and maybe the trans from the '89 into the '84 (frame damaged on the '89).
Is this a weekend project for someone who has done engine/trans conversions before?
Tried google and didn't find any useful info, just a lot 'For Sale'.
Any major gotchas'? Like different engine mounts or other structural changes? Driveshaft lengths OK going from manual to auto? How about wire harness diffs?
Do I jump into this one or leave it alone? Remember, this is a favor, no money involved....
Thanks,
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 09-20-2003, 08:55 PM   #2
method2mymadnes
method2mymadnes's Avatar
If the 84 is anything but a 4.3, nothing will bolt up including the motor mounts or the transmission. I would use all the 89 4.3 stuff including the engine harness.
method2mymadnes is offline   Reply With Quote
Old 09-20-2003, 11:01 PM   #3
ItsNotABlazer
The full convertible guy
ItsNotABlazer's Avatar
Might check out www.s10forums.com or maybe its www.s10forum.com One is a much better site than the other but I cannot recall which is which lol. They have a pretty informative message board there that might be of help.
Brad
2012 Kawasaki Vaquero (Lime Green)
2000 BMW 740iL
1995 Chevy ECSB riding on air
1975 GMC Jimmy 2WD lowered 4/6
1972 Chevy Trazer soon to be roadster
1965 Mustang 289/3 speed (friends dad bought it new)
1964 Chevy C10 (dad bought it new)
ItsNotABlazer is offline   Reply With Quote
Old 09-21-2003, 09:06 AM   #4
TODDS 72
Not the nightly winner
TODDS 72's Avatar
if you have both trucks side by side you'll have everything you need,but it will prolly take you a couple weekends to do the hole job.
good luck
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
Old 09-23-2003, 08:16 AM   #5
Tink
Tink's Avatar
Check http://forums.s-series.org/. The guys there are pretty knowledgable.
As long as the trucks are the same length (both short box or extended cab....), and you switch the engine and tranny you should be fine. The 84 tranny will probably not bolt up... I imagine the 84 has either the 2.5L iron duke or the 2.8L. You would have to use the wiring harness and computer from the 89 as well. Also, you may want to check the gears in these trucks to make sure you aren't "winding-out" the 4.3L to turn the gears in the 84's rear. The RPO code for gears in usually the G codes in the glove box (i.e. GU6=3.42)
This will probably take quite a few weekends and it will probably be best to take off the whole front clip and fenders. Also, be sure to well label everything.
If you run into any trouble with the 89 4.3L or tranny wiring or anything, let me know... I have an 89' 4.3L and a 91' 4.3L I can take pictures of to send you.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
