Old 03-25-2016, 09:55 PM   #1
drewbert41
drewbert41's Avatar
Valve cover install issue
I ran into a problem when putting on new valve covers today. The new ones hit the part that is circled in yellow. What is this part? It is bolted to the manifold. Can I move it? If not is there a smaller one? My old valve covers are pictured and they clear it ok.
drewbert41 is offline   Reply With Quote
Old 03-25-2016, 10:28 PM   #2
46stude
Re: Valve cover install issue
That is your EGR valve.
46stude is offline   Reply With Quote
Old 03-25-2016, 10:32 PM   #3
basketcase
basketcase's Avatar
That is the EGR valve. If your state requires a visual emissions check for your year, meaning that they have to be able to see everything that is supposed to be there, then it must be there. If not, trash can it. You can get EGR block off plates from the aftermarket or make one yourself using the gasket as a template. Make it out of .250 steel plate. Make sure you block off the vacuum line too.
You will never miss the EGR except your engine may smooth out and run better without it.
Tom
'69 swb stepside in progress.
'59 Corvette lifetime project
basketcase is offline   Reply With Quote
Old 03-26-2016, 12:03 AM   #4
drewbert41
drewbert41's Avatar
I had egr problems with my S10 all the time. I didn't realize they even existed back when this truck was made.
Old 03-26-2016, 12:32 AM   #5
bronze 72 super
bronze 72 super's Avatar
They didn't exist back in the early '70's. Your intake is a newer one, check on the back for a production date. Anything with a E.G.R. is late '70's and beyond.
1971 Cheyenne Super C-20 402 4 speed
1970 El Camino L-48 350
1999 Chevy Z-71 Extended Cab 4x4
2000 Tahoe Z-71
2004 Monte Carlo S.S. Supercharged Dale Earnhardt Intimidator
1970 Chevelle, Malibu Sport Coupe
2007 Harley-Davidson FLHX Street Glide
bronze 72 super is offline   Reply With Quote
Old 03-27-2016, 09:39 AM   #6
basketcase
basketcase's Avatar
You're right. I didn't catch that.
Tom
