04-30-2016, 08:15 AM | #1 |
Factory Original 16.5" steelies?
I am not sure if these are the same steel wheel that came as an option on a 1972 Blazer. These have holes for clips. I am pretty sure that the originals did not have nubs to hold a hub cap. Please share what you know about the original 16.5x8 wheels and if you have a picture I would like to see it. Thanks.
1972 K5 Blazer Cheyenne 1966 L72 Corvette Convertible 2016 GMC Yukon Denali |
04-30-2016, 08:30 AM | #2 |
Carpe manana
Re: Factory Original 16.5" steelies?
I don't believe these had nubs for caps and caps were not included from GM when so equipped. The 8-lug 16.5" and 6-lug (3 nub) wheels do accommodate caps. Someone else please confirm. The Chevrolet blazer brochure for the 72 model year has an ochre k5 w what I believe are 16.5" wheels and it has no caps.
05-01-2016, 06:37 PM | #3 |
I am surprised that there is not more info out there on the correct 16.5" steel wheels.
05-01-2016, 07:04 PM | #4 |
Carpe manana
Not too common option to begin with let alone 40yrs later. I'm guessing most were discarded over the years. BFG dropped their 16.5" at. I expect those on my k20 will be changed for 16" when the time comes.
05-01-2016, 07:48 PM | #5 |
Here are some 16.5 x 6.0 6-lugs wheels I have. I believe they were also used on G10 vans as well; 3 nubs.
I read in the parts for sale section that another member stated they would fit disc brakes but I can't confirm that. They have a 4" backspacing and I mounted them on the rear of my suburban just to see if they fit with a 9.5" wide tire and they do.
MusicMan70 1961 GMC Suburban |
06-06-2016, 08:18 PM | #6 |
My 72 K5 CST came from the factory with 31 X 10.50 X 16.5 tires and wheels, according to the build sheet. No hub caps mentioned.
