Closed Thread
Old 10-08-2015, 06:12 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Stainless steel rocker panels
Is there a company out there that produces stainless steel rocker panels for our trucks? It sure would be nice not to have to worry about rust in that area. Put new rocker panels in my daily driver 16 years ago. And now they are roached out again needing replacement both inners and outers
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline
Old 10-08-2015, 07:05 PM   #2
Xeen
Xeen's Avatar
Re: Stainless steel rocker panels
Remove the regular steel rockers and then take them to a metal fabricator and tell him to reproduce them in detail in stainless.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline
Old 10-08-2015, 07:21 PM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
I was thinking about this the other day. When installing new rockers, why not cut the bottoms off and coat the inner side with POR15? They'd be protected by the POR15 and they'd also be open so they would dry out all the time and not hold moisture. You wouldn't be able to see that there's no bottom unless you looked underneath.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline
Old 10-08-2015, 07:49 PM   #4
Redline novdog
Redline novdog's Avatar
That would be a 70k truck,piece by piece stamp it stainless. put it together,BAM timeless! Hope somebody does it. that would be sweet! I have not heard of stainless panels,but maybe you are on to something its70!!!! I'm In!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline
Old 10-08-2015, 07:56 PM   #5
FirstOwner69
FirstOwner69's Avatar
The truck John DeLorean would have built?!?!?!?!?!
FirstOwner69 is online now
Old 10-08-2015, 08:25 PM   #6
tommys72
tommys72's Avatar
You beat me to it, I was gonna say the same thing
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline
Old 10-08-2015, 09:06 PM   #7
drewbert41
drewbert41's Avatar
16 years ago did you do anything to seal the insides of them when installing? Or did you do the same thing GM did and just leave the insides bare metal?
drewbert41 is offline
Old 10-08-2015, 09:20 PM   #8
lts70
1970 Daily Driver
lts70's Avatar
I wonder how much harder it would be for the companies that build the steel rockers to stamp them out of stainless. I know I would pay the premium for the upgrade.
lts70 is offline
Old 10-08-2015, 09:21 PM   #9
Jrainman
Jrainman's Avatar
the reason why it is not done is the fact of welding two different types of metals is difficult to weld , being SS has very low carbon amounts
it is not that it cant be done but you really have to have good equipment to get good results ,
Tig or brazing would give best results though,
Well there is always the new Ford aluminum body F150
I will say I am not a Ford guy but the paint on those new aluminum body f150 is something to look at , I looked at one at a outdoor show in a dark green and the paint was amazing almost flawless
Jrainman is offline
Old 10-08-2015, 09:36 PM   #10
bill3rail
bill3rail's Avatar
Would love to see a set of these! I'm not a welder and I was curious about dissimilar metal welding procedures...
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline
Old 10-09-2015, 01:40 AM   #11
In The Ten Ring
I am a novice welder but I am in a welding class. I thought the same thing concerning the welds.
In The Ten Ring is offline
Old 10-09-2015, 02:27 AM   #12
Greasey Harley
Greasey Harley's Avatar
I don't know about SS body panels but, my truck gets the garden hose treatment regularly. Turn it on and stuff it in the back corners inside the cab and just let it run. Wash out all the dirt/salt (crap) that is packed into the cab and rockers. The dirt is what holds the moisture and rots the metal. I also do this to my fenders and cowl. I am always amazed at how much mung comes out.
Yes, the interior gets very wet when I do this, it dries though.
clean trucks don't rust
Greasey Harley is offline
Old 10-09-2015, 03:41 AM   #13
Clavo106
SS ???? /// IF THIS WAS NEVER GOING TO BE PAINTED IT WOULD BE OK./ .. it would probably be better to make the hole truck made of aluminum lite weight and you would just have to polish it every so often. my 2cents
Clavo106 is offline
Old 10-09-2015, 07:48 AM   #14
The problem is when stainless touches steel it ain't so stainless anymore. You need all stainless or it will give out where they meet. Just look at a stainless exhaust system. Anywhere the metal mixes is where they fail.
special-K is offline
Old 10-09-2015, 10:51 AM   #15
Fitz
You forgot that the weld is now a mixture of metals and corrosion starts aggressively at the weld line due to electrically dissimilar metals coming together with moisture!
Fitz is offline
Old 10-09-2015, 11:03 AM   #16
EARNHARDT#3
Slap em on with seam sealer LOL
Old 10-09-2015, 11:04 AM   #17
michael bustamante
michael bustamante's Avatar
i actually read Chevrolet is going to be doing the same thing to our chevy and GMC trucks
1967custom
michael bustamante is offline
Old 10-09-2015, 11:23 AM   #18
dell72
You could use panel bond adhesive like some new cars use.
dell72 is offline
Old 10-09-2015, 11:37 AM   #19
kingstrider
kingstrider's Avatar
FWIW "stainless" is a misnomer and will rust given the right conditions. Even the highest grade of stainless steels found in guns or knives will rust if not cared for. Seems like a long run for a short slide to me.
1972 Cheyenne Super swb:
http://67-72chevytrucks.com/vboard/s...d.php?t=684318
kingstrider is offline
Old 10-09-2015, 12:42 PM   #20
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I like the idea and would spring for the difference in material costs. As for the welding aspect? The high carbon T-309E is the "stainless to mild steel" alloy in wire or stick and I never seen a rocker rust out at the welds so it's a very doable endeavor. I'm a retired certified welder, it was my job for 40 years to know these things...Aluminum? Now there's a different breed of cat. Nobody's come up with the weld process for aluminum to steel, "yet." As far as those Fords go, the whole fastening process of panel to panel and body to frame has changed completely. No welds involved and are fastened with high tech rivets that bond the aluminum when they are shot into place by mainly robots. I was fortunate enough to work for Ford at the Claycomo truck plant installing some of the various conveyor systems through the years...That's why I drive Old Chevy's!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline
Old 10-09-2015, 12:53 PM   #21
DarkFlounder
Pop rivets worked for my dad, they'll work for this!
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 10-09-2015, 02:03 PM   #22
WarMonger
WarMonger's Avatar
you got 16 years out of the last set. That is pretty good. Just put new ones on and go another 16.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline
Old 10-09-2015, 03:10 PM   #23
BrianG
BrianG's Avatar
I've thought about trying to spay some oil up in the drain holes of mine every so often. Is this a good, or bad idea. If this might help them, what oil or spay should I try spraying up there?
BrianG is offline
Old 10-09-2015, 03:34 PM   #24
EARNHARDT#3
Definitley a good idea. Just some WD40 would do fine. Put the red straw on the can and hose the inside of the rockers real good. My dad bought a 67 LeMans the original owner who used to spray WD behind all the lower trim and the car had basically no rust there. Whereas this was a very common place for them to rot out even 25 years prior to this.
Old 10-09-2015, 04:11 PM   #25
unclesalty
unclesalty's Avatar
I bet aluminum would be easier to fab than stainless, some of the modern panel adhesives would probly hold them on fine. I just did both of mine and por-15ed the insides. I haven't put the inners on yet, I guess I will hopefully before the snow. It would be nice to have, aluminum body panels, but the cost would be scary. I would do the cab corners and rockers if they were available- why not? Sounds like a great idea to me!
69 GMC 2500 custom longbed
350 4bolt,steel crank,q-jet,edelbrock streetmaster
400th
4.10 1ton floater,8 lug goodness
unclesalty is offline
Closed Thread
