Old 09-02-2016, 11:38 AM   #1
grillzy
Factory Body Shimming
I am looking for the factory picture and description of what positions to shim the body mounts to get the gaps correct. Thanks
grillzy is offline   Reply With Quote
Old 09-02-2016, 11:45 AM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Factory Body Shimming
From the factory assembly manual...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 09-02-2016, 12:10 PM   #3
grillzy
thanks thats perfect!
Old 09-02-2016, 01:07 PM   #4
Keith Seymore
Keith Seymore's Avatar
Attachment 1566852
Very nice.
It's "as required", to account for build variation in the frame and body in white, as time goes on.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-02-2016, 01:44 PM   #5
A1971Blazer
Originally Posted by Keith Seymore View Post
Very nice.
K
A guy on FB had an issue..... when he removed the top, the doors hit at the rear...turns out that the body mounts were replaced with the top on and the shims weren't reinstalled....he said the rocker boxes were in good shape too.
When the top came off the body drooped slightly...I think that whenever the mounts were replaced and the bolts tightened....it put the body in a slight bind that manifested itself when the top came off..
not sure of the color though..I don't think it was white...?
Also, OP...I assume your rocker boxes are good..?
1967 C10 Step side
1968 C10 Step side
Old 09-02-2016, 02:46 PM   #6
Keith Seymore
I had "as required" in quotes, because it was a bit of a misnomer.
What we used to do for fender shims is tape a packet together, like 3 shims, and we would run those all day whether the truck we were currently building needed it or not.
Eventually the final repair supervisor would call back and say something encouraging, like "SEYMORE!! YOU IDIOT!! WTH ARE YOU THINKING?!?! ALL THESE FENDERS ARE RUNNING HIGH!! ARE YOU EVEN LOOKING AT THESE TRUCKS?!? TAKE A SHIM OUT BEFORE I COME BACK THERE AND SHOW YOU HOW TO DO THIS!!" I can just imagine the spittle flying into the phone mouthpiece.
So we would start running a new shim pack, like 2 shims, until he called again with his latest observation.
Basically it was to address "macro trends". You had about 45 seconds to complete the truck in front of you and move to the next one; that's not enough time to fit and re-fit each individual truck.
K
1979-1986
1986 - 2019
Old 09-02-2016, 02:58 PM   #7
A1971Blazer
K
I always wondered how the assembly line managed to get them as close as they did..... knowing that there was so little time to do so....that method makes sense...but where did the final fit take place...final repair?
I know that fit and finish on trucks, back then, wasn't as much of a priority as it is now days...'cause after all, it was "truck"....not a mall crawler...
Good info K...!
1967 C10 Step side
1968 C10 Step side
Old 09-02-2016, 03:50 PM   #8
grillzy
Great forum. Got all the body mounts replaced today.
Old 09-02-2016, 04:12 PM   #9
A1971Blazer
sweet....let's see some pics......
1967 C10 Step side
1968 C10 Step side
Old 09-02-2016, 05:27 PM   #10
grillzy
Had to tip Old Blue up so I could wash out all the grinding dust from grinding the welded heads off. So much quieter over the bumps now!
Old 09-02-2016, 09:29 PM   #11
A1971Blazer
Nice.....how much did you shim...?
1967 C10 Step side
1968 C10 Step side
Old 09-03-2016, 07:56 AM   #12
grillzy
Put back in the 2 factory shims at #1 spot both sides then added 1 at #1 passenger side and 1 at #2 passenger side.
Old 09-03-2016, 10:18 AM   #13
Cape Codder
Cape Codder's Avatar
I worked at GM dealership body shops from 1974 to 1982. We did a lot of realignment if someone complained about gaps or panel alignment. The pickup doors were the hardest to get to fit the openings right. Fenders and hoods had lots of adjustment.
Cape Codder is offline   Reply With Quote
Old 09-04-2016, 03:32 PM   #14
Keith Seymore
Good info K...!
Yes - this technique would get you close on the majority of vehicles.
There was a repair station at the end of my area. There was also a short moving repair line (two, actually) at the end of final line. If they could fix them there while on the move then they would; otherwise it would be out to a stationary repair stall in "heavy repair" for the really bad ones.
I should add that some of the repairs did not consist of removing the bolt or adding/deleting shims. Often the repair consisted of bending, twisting or hammering while the line was moving.
K
1979-1986
1986 - 2019
Old 09-04-2016, 07:21 PM   #15
A1971Blazer
I should add that some of the repairs did not consist of removing the bolt or adding/deleting shims. Often the repair consisted of bending, twisting or hammering while the line was moving K
Now that I could have guessed......doing that job day in and day out...day after day.....a line worker would soon learn exactly where to place a hammer strike.......
1967 C10 Step side
1968 C10 Step side
Old 09-05-2016, 08:08 PM   #16
Ebully72
Didn't know if I could jump on this one for some advice. I planning on some winter work on mine, but I'm impatient and started pulling some stuff off. What I was wondering if I should work on the gaps before I take it apart or just mess with the gaps after new rockers and floor pan,cab supports. Thanks Bill
Ebully72 is offline   Reply With Quote
Old 09-05-2016, 08:32 PM   #17
A1971Blazer
Definitely after.........welding and new metal will change everything to a certain degree.........
1967 C10 Step side
1968 C10 Step side
Old 09-05-2016, 08:43 PM   #18
Ebully72
Thanks for the help. Disassembly will continue.
Old 09-05-2016, 08:53 PM   #19
Cape Codder
I disagree if it doesn't line up before replacing parts it may be worse after. I would get it all aligned up and fitting as you want it and keep checking as you weld in the new panels. You need to fit the rockers to the door with the doors fitting the body.
Old 09-05-2016, 09:30 PM   #20
Ebully72
The gaps aren't that great now which is why I was questioning it. What do you think about putting the factory shim count back in,right now the passenger side has 4 in the #2 spot and 2 in the #1 spot. The driver side has 1in the #1 spot and 2 in the #2 spot. I guess that would probably be a good place to start.
Old 09-05-2016, 09:33 PM   #21
A1971Blazer
It's hard to line up rusted out and missing sheet metal......
1967 C10 Step side
1968 C10 Step side
Old 09-05-2016, 11:23 PM   #22
Cape Codder
If it is that bad you bolt the doors on prop the body till they fit and weld bars inside to hold it in place then start replacing metal. To just start welding parts on without having the panels where they belong is asking for trouble.
Old 09-06-2016, 09:19 AM   #23
A1971Blazer
Is the hardtop on...?
1967 C10 Step side
1968 C10 Step side
Old 09-06-2016, 02:27 PM   #24
Ebully72
Yes the top is still on . The metal there isn't horrible could have driven it the way it is. Rocker boxes in tact, some 1" holes in the rocker.
Old 09-06-2016, 03:50 PM   #25
A1971Blazer
Then I would think you could start replacing the rockers and floor. Like CapeCodder says keep everything aligned as you go....then there shouldn't be much shimming to get the gaps adjusted.
1967 C10 Step side
1968 C10 Step side
