Old 08-19-2011, 08:19 PM   #1
smorg007
smorg007's Avatar
Why is my A/C blowing warm air
I had the whole system gone through last summer and it worked great in our triple digit climate. Now it blows warm air. You can see by the pics that the lower tube ice's up instantly when I turn it on. I checked and replaced one vacuum line and reconfirmed heater core shut-off valve was functioning properly, baffle rod inside core housing that diverts the air moves with cable. Any ideas is appreciated.
smorg007 is offline   Reply With Quote
Old 08-19-2011, 08:32 PM   #2
JimKshortstep4x4
Re: Why is my A/C blowing warm air
Have you checked the pressures in the system?
It looks like in the picture that the freon is not flowing through the evaporator since the outgoing line is not frosted.
Is that a hose clamp on the refrigerant line? If it is and you are using 134A then it is possible that you have a leak and not much refrigerant is in the system.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-19-2011, 08:33 PM   #3
umwtnt
umwtnt's Avatar
Normally thats a sign of low refrigerant. Install the gauges and check your pressures.
The more I learn, the more I find out I don't know.
69 Chevy SWB w/67 front end
4 wheel discs
468 BB 700R4
Bagged
Coming around slowly
umwtnt is offline   Reply With Quote
Old 08-19-2011, 09:40 PM   #4
lil hoodlum
lil hoodlum's Avatar
I agree, it appears that you are low on freon. You probably have a leak.
Good luck,
Keith
lil hoodlum is offline   Reply With Quote
Old 10-24-2016, 10:14 AM   #5
a1vintage69
a1vintage69's Avatar
Stan, you haven't been on here in awhile. I used to see ya at the shows. do you still have your truck? anyways I am looking for lower nos wood grain trim. did you sell all you had? or any other c10 parts. please let me know. Steve Jones in Redding . June Jones' son. I will send a pm.Thanks
a1vintage69 is online now   Reply With Quote
