Old 09-25-2017, 09:04 AM   #1
MP&C
MP&C's Avatar
Keg Trailer
Never know what you see pull into the shop. Got a phone call last week to look at a damaged trailer...
Apparently someone that had borrowed this for an event did not understand the operation of a Bulldog coupler. Near as we can tell, the split coupler was never compressed when the collar was moved forward, so it rested against it. With a bit more force they were able to insert the safety pin, and the first bump started the chain of events.
Looks like the did some plowing in the grassy area of our local county fair...
....just before making contact with the back of the tow vehicle..
Inside the operating room on Tuesday night, Jake and I pulled off the carnage of exterior shell... The corner upright had been broken clean off its welds..
....as well as sporting a nice bow...
Since we had the correct size square tubing in stock, we cut a piece to length, welded in place, then Jake abraded with the DA and painted with some SPI epoxy primer.
The wiring harness also took a beating, we picked up a new harness from TSC and will get that installed tonight, and see if we can get the outer skin bent and installed..
Robert
MP&C is offline   Reply With Quote
Old 09-25-2017, 09:07 AM   #2
MP&C
MP&C's Avatar
Re: Keg Trailer
Remainder of the repairs on Thursday night/Friday...... trimming the painted aluminum panel prior to bending the long folds
Installed.....
Added new hooks on the safety chains
....new wiring harness,
....fabricated a new handle and used a bicycle grip, replacing the duct tape repaired original....
Roof seams were sealed using mesh to help make the repairs more permanent..
All ready for some keg action.. Painted panel is a bit too bright, this was owner supplied; he had ordered it to make an outfield sign at a local ball field, re-purposed it to get the keg trailer back in one piece for a large wedding this coming weekend.
Robert
Old 10-03-2017, 01:22 PM   #3
Low Elco
Re: Keg Trailer
Nice repair job!
Low Elco is offline   Reply With Quote
