Old 02-04-2017, 10:26 AM   #1
rex01atv
What to look for when buying 67-72 c10 with LQ9(6.0) swap?
Need help I am looking at buying a 72 c10 swb with a already converted 04 Escalade engine/trans installed. What are some things to look for to make sure install was done correctly? Wiring? etc..
rex01atv is offline   Reply With Quote
Old 02-04-2017, 11:16 AM   #2
clay68c10
clay68c10's Avatar
Re: What to look for when buying 67-72 c10 with LQ9(6.0) swap?
Bring along a generic OBD scanner and see if it has any codes. This will be an indication of how well the swap was done from a programming and wiring standpoint.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-04-2017, 03:12 PM   #3
weq92f
weq92f's Avatar
The only way I would consider it for purchase is if that motor looks the business and I can show beyond doubt that it is as advertised. If they simply took a 100k+ mile drivetrane from the junk yard and stuffed it into the truck for quick sale, then it's likely not worth your time or money.
Go in assuming that it is a 5.3 liter vortec with a 4l60 tranny with 400k miles. Then go about disproving that by finding the correct markings on the engine block ( should be a 6.0 stamped into the block if it is a 6L ), digging into the OBD computer data, finding the case marks on the tranny/rear end and just in general researching how to identify the LQ9 positively as well as determine whether the tranny belongs with that engine.
Examine the frame rails under the hood to make sure no cutting was done to stuff that engine in there.
Then fire that thing up and put your hands on it. It shouldn't feel like it is laboring to idle, missing or doing anything but purring nice and smooth.
Your OBD scanner will tell you whether the codes have been recently reset, which would require a certain amount of driving be done before you can determine if there are any new codes. So you may need to drive it 50 or 100 miles to get the computer to reassess trouble codes from the various components/sensors.
Hth,
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-05-2017, 09:58 AM   #4
Kennuck
Kennuck's Avatar
Like weq92f said check that the frame hasn't been hacked to fit the manifolds or AC pump. If done right there is no need to hack the frame.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 02-05-2017, 11:00 AM   #5
jessemthompson
Take it out for a test drive as well. That will tell you a lot.
jessemthompson is offline   Reply With Quote
Old 02-05-2017, 11:58 AM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: What to look for when buying 67-72 c10 with LQ9(6.0) swap?
If it's a Escalade it should be all aluminum engine. No steel! The motor will have the 6.0 stamp on it also as stated.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
