06-03-2017, 07:14 PM | #1 |
You pick and pull it yards finds
06-04-2017, 12:10 AM | #2 |
Re: You pick and pull it yards finds
nice find our pick an pull has 3 of these trks but they been picked thru already
77 swb starting all over again. |
06-04-2017, 12:24 AM | #3 |
06-04-2017, 03:22 AM | #4 |
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
06-04-2017, 09:16 AM | #5 |
coolest/rarest thing i found at pick and pull was a set of flat top knuckles for a dana 44. actually went there looking for them knowing no way i would find a set. got lucky i guess
06-04-2017, 12:21 PM | #6 |
06-04-2017, 12:45 PM | #7 |
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
06-04-2017, 12:49 PM | #8 |
This was about a month ago, but I went to get a seat from a local yard, and came back with 2 seats. The FIND was, that there was a stack of grilles in the bed of the truck.
06-04-2017, 01:03 PM | #9 | |
My uncle might get the bucket seats and the center console from the suburban. |
06-04-2017, 01:10 PM | #10 |
Forgot about that find. There were already out of vehicle, so I'm not sure exactly what these came out of.
06-05-2017, 10:41 AM | #11 |
Found these two on the same vehicle. Someone had taken the entire front clip off a 1980 except for the radiator core support, the left outer, and inner fender. All were nearly rust free. The outer fender was bent where the yard had set the truck on the supporting tire rims. Wasn't looking for a core support that trip but an almost labor free one was too much to pass on. $30 for the core and either $5 or $15 for the inner fender.
On a different trip, found a cargo tray for my 09 Escape. $5. Dealer price was somewhere on the high side of $300. |
06-06-2017, 01:19 PM | #12 |
i would guess early 90s k5 blazer or suburban. thats a k5 blazer center console and the fabric of that seat is the same as my 1990 c1500 silverado bench seat. and for as old and as ugly as my truck is my seats too look that great.
06-06-2017, 06:15 PM | #13 |
06-06-2017, 07:05 PM | #14 |
Damn that is a nice seat. How much was the yard asking for it?
06-06-2017, 07:06 PM | #15 |
Those seatbelts are nice too!!
06-06-2017, 07:32 PM | #16 |
06-07-2017, 11:58 AM | #17 |
Are you going to go back and get the seat and belts, and use them?
06-07-2017, 12:10 PM | #18 |
06-07-2017, 12:25 PM | #19 |
That's good if you can use them. Just thinking, if you did not use them, it would be almost worth the drive.
06-08-2017, 10:46 PM | #20 |
6.0 $1300
06-11-2017, 01:22 AM | #21 |
My latest score is not Square related exactly. I go out to my Pick N Pull specifically for 73 to 81 square parts. well they were having their 50% off sale so I decided to poke around and see if i could find a few things. after walking the truck line and seeing only stripped squares I decided to walk the GM car line, maybe find a set of Caddy horns or relays etc. as I am walking I run into a 74 Chevelle ........... I just hit the lottery! there are never 70's cars in the yard here. Actually there were 2 gm 70's cars that day the Chevelle and a 79 Vette.
My daily driver is a 75 El Camino. So it's going to be a long day. I am going to strip anything good off this car. My Elkie is a basket case it is basically 3 cars of parts that I reassembled to run. any way got a cherry grille and headlight assemblies both of which look better to me then the 75 design so I snag up those also all the marker lights and bezels, brackets, moldings, relays, seat belts (black), a/c ducting, glove box and door, winshield trim. as i am looking over the rear end of the car (not much that works on an elkie) I jump under it just to eyeball the rear axle. standard 10 bolt in appearance. pop the cover off and behold a beautiful posi diff. with 3.08 gears (elkie has 2.76). Ok my day just got even longer out came the rear axle. the Chevelle also had a TH400. I needed a front pump for a spare 400 I have, so I snagged that too. Since I was in the trans I also yanked out the speedo gears too. I rolled up to the register with a heaping cart. I left the yard only $188.00 lighter
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. Last edited by Titomars; 06-11-2017 at 01:32 AM. |
06-11-2017, 01:44 AM | #22 |
That was quite the score all right!!!
06-17-2017, 10:44 AM | #23 |
06-17-2017, 04:04 PM | #24 |
06-18-2017, 10:35 AM | #25 |
A couple of van grilles. The grilles are pretty busted up, but all the trim moldings & bowtie are pretty nice.
