Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1988 - 1998 GMT400 Chevy & GMC Pickups Message Board > projects and builds 88-98
Old 02-13-2017, 10:16 PM   #1
3v0
1991 K1500 project questions
Recently picked a V6 5 speed K1500 truck with six bolt wheels. Does this make it a heavy duty 1/2 ton or did all 4WD 1/2 tons use six bolts. Although the truck has many minor problems the body is rust free and when you hit a bump the entire truck moves together rather then as a collection of parts. It feels solid. The hood alignment had me worried about the frame but it runs straight down the highway.
I am looking for the dash cluster schematic with the pin numbers for the connector. I am having problems with the cluster illumination. All the gauges work except the mechanical odometer which is worn out.
3v0 is offline   Reply With Quote
Old 02-14-2017, 04:10 PM   #2
54 jimmy
54 jimmy's Avatar
Re: 1991 K1500 project questions
all k1500 series trucks came with 6lug as they were 4x4 2500 up were 8lug. as for the movement you probably need shocks. my 1996 that I just bought had the same issue bad shocks. nice truck by the way.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 02-14-2017, 04:20 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
There were some heavy duty 1/2 trucks that had a 7200 GVW.
And there were some light duty 3/4 ton trucks that had 7200 GVW(and 6 lug)
But there weren't any 5 lug 4wd trucks.
95 S_Trucker is offline   Reply With Quote
Old 02-18-2017, 05:04 AM   #4
3v0
Re: 1991 K1500 progress
By the vin it is a standard 1/2 ton. Seems tall.
Making good progress. Removed the make shift ignition from the ash tray and now have a working factory ignition switch on the column.
Found the wiring diagram here http://67-72chevytrucks.com/vboard/s...d.php?t=465868
Note to anyone working on a non tilt wheel: there are hidden screws on the back side of the plastic shell that holds the turn signal cam etc. To get to the ignition switch pull all the plastic off the steering column and then remove these screws from the back.
The cluster illumination lamps now work and the tail lamp fuse no longer blows. Cleaned up the instrument cluster but the odometer wore out at 46K. Cleaned it up but it jams so I left the wheels out. Looks like I may have the trip odometer working. Good enough for now.
Replaced the brake booster.
Had IAC and low fuel pressure codes when I started. Not sure why but they are gone. I have only driven it a handful of miles during testing. So they may come back.
Next I plan to give the engine some TLC. Will revisit the forum post on rough running engines. Need a front wheel balanced or new front shocks.
Old 08-05-2017, 11:42 PM   #5
diveplane
great truck keep her clean and factory standard imo but everyone is different.
the trip odometer you'll find if u open the gauge cluster it's a easy fix, there's a spring inside you'll find that's broke i bet, as u dont reset these trip units while moving.
diveplane is offline   Reply With Quote
