Old 09-17-2009, 11:26 PM   #1
budder71
Tri plus oem parts ?
I have seen on a couple of for sale threads some TRI PLUS doors,fenders, etc
and they are explaining that Tri Plus has "retooled" there press/stamping process and the parts are up to NOS standards on thickness and tooling..
Has anyone else heard this or used any of the Tri Plus parts lately ? and if so what is the quality and fit ?
budder71 is offline   Reply With Quote
Old 09-17-2009, 11:55 PM   #2
BIGBLU 72
BIGBLU 72's Avatar
Re: Tri plus oem parts ?
My dad sold them thru his biz and used them when he built his 68 crew cab dooley and i never heard any gripe from him about or any of his customers...my .02
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 09-18-2009, 12:02 AM   #3
HuggerCST
HuggerCST's Avatar
I agree, from what I've seen and heard, most of it is pretty good stuff. I think Tri-plus is made by "Key" parts.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 09-18-2009, 12:53 AM   #4
jaros44sr
jaros44sr's Avatar
Heck, over 3/4 of my truck is Tri-Pro, with no problems! Even bought OEM front fenders, just to see how they would fit up with remanufactored parts...no problem! You will have to shim and adjust any body part you put on your truck, so why not start with a dent and rust free body panel that does not need a 1/2 lb of bondo.
Guys will bash the product, but give it a chance and then you can decide. If it doesn't work for you , you can always resell it
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-18-2009, 07:37 AM   #5
vtblazer
vtblazer's Avatar
Some of the best after market sheet-metal out there IMO.
...and they sell blazer specific doors!
vtblazer is offline   Reply With Quote
Old 09-18-2009, 10:32 AM   #6
D.PASSMORE
One of the First
D.PASSMORE's Avatar
VT,
How did the doors line up with the body. Any 2x4 adjustments??? Is there a big difference in weight?
Budder71, not to hijack your thread but I've always have been told that tri-plus is the best AM Sheetmetal. I know that there rocker panels are better than OE.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-18-2009, 10:52 AM   #7
Burt4x4
Burt4x4's Avatar
Hy VT, why does the box the door is in only go up to 71? Is the 72 door different?
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 09-18-2009, 10:55 AM   #8
turp mcspray
turp mcspray's Avatar
I use a lot of aftermarket sheetmetal, and have found the Tri-plus stuff to be some of the higher quality on the market. I am also curious about how your doors fit. It seems that door shells across the board, have some fitment issues. I hope your blazer doors work out well, and will be waiting to hear about them.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-18-2009, 11:13 AM   #9
budder71
BUMP BUMP !!! thanks guys for the information !!!! great feedback....
Old 09-18-2009, 11:28 AM   #10
Luba
Luba's Avatar
Where are these parts made?
Luba is offline   Reply With Quote
Old 09-18-2009, 12:10 PM   #11
litebulblsc
litebulblsc's Avatar
Yes 72 doors are different. They use the plastic door panels and have an extra screw
litebulblsc is online now   Reply With Quote
Old 09-18-2009, 08:57 PM   #12
1sik52
Is this true?
1sik52 is offline   Reply With Quote
Old 09-18-2009, 09:00 PM   #13
Rochlow
Does anyone have a site or contact to order triplus parts?
Rochlow is offline   Reply With Quote
Old 09-18-2009, 09:31 PM   #14
lolife99
67-72 parts collector,…
lolife99's Avatar
Member/Vendor: Tri-Pro Automotive
http://67-72chevytrucks.com/vboard/member.php?u=29975
Keith
Convert to disc brakes.
Old 09-18-2009, 09:36 PM   #15
Rochlow
Thanks.. Still trying to learn how the boards work...
Old 09-18-2009, 10:30 PM   #16
Rochlow
Sweet.. A place to buy part and not have to drive 20hrs to get them...
Old 09-19-2009, 05:59 AM   #17
vtblazer
vtblazer's Avatar
Correct, different door, different part number all for the small screw under the wing window.
Old 09-19-2009, 10:15 PM   #18
71 super
71 super's Avatar
Just a fyi I installed a tri plus rocker in one side of a new cab for little brother's 4x4 and a NOS gm in the other side, the tri plus fit better than the GM unit did as was eqal in heft thickness etc. I sold a pair of NOS rockers after this because the tri plus are that good.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-20-2009, 12:14 AM   #19
1sik52
I got a pair of Tri Plus rockers and so far the passenger side isnt fitting worth a sh#*!!! I hope it gets better especially being since i have to redo the drivers side
Old 11-17-2011, 11:07 AM   #20
bamafrost
bamafrost's Avatar
Re: Tri plus HAS to be better than Goodmark
Haven't used TriPlus...wish I had. Have struggled with every item I bought from Goodmark. They make crap stuff in my opinion. Cheap, flimsy junk that doesn't begin to fit. I am out thousands using their junk doors, hood, tailgate, fenders...agggh!).
TriPlus, or re-skinned OE would HAVE to be better.
Bamafrost
"Wars fought, uprisings quelled,
Coup d'Etats planned...right after my nap".
'68 Rambler American 2 door post
Built 340/727/8.75 w 3.73 posi
'68 C10 shortie soon to have a 2.5/4 drop
and new Americans: 16" x 8" chrome IROC's
bamafrost is offline   Reply With Quote
Old 11-17-2011, 01:09 PM   #21
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I agree with the rockers. I was impressed with Tri-Plus when I matched with a NOS set of Rockers. Curious about the doors: metal thickness, weight and fit...
Old 12-31-2011, 12:10 AM   #22
Jkmyers84
I am also interested in the fit of the doors and on a tri plus tailgate I am in need of all that for my blazer.
Jkmyers84 is offline   Reply With Quote
Old 12-31-2011, 12:24 AM   #23
dwcsr
Hollister Road Co.
dwcsr's Avatar
Doors are tricky and your lucky if it fits with no reworking. The Door they sell fits a truck they have and the door opening on that truck. Your door opening may or may not be different. To think your Door opening is exactly the same as all trucks of the same year or model and is still the same dimension as it was when it came off the line 40 years ago is not realistic.
NOS is not a standard of fit, OEM is. NOS is nothing more than New Old Stock and still could be a repop that's 20 years old. With that said Triplus and Dynacorn have some of the best fitting panels and doors.
Old 12-31-2011, 09:41 AM   #24
jaros44sr
jaros44sr's Avatar
i agree with everything mr. chapman said....
i hung those doors on their truck, but, i replaced the full floor, and firewall. so, i had the advantage to put things where i wanted them for fit! i think from what i read, that the problem was with the fit of the window frame (top, rear), but you should not have a problem in that area, since you wont have it to deal with
i also hung a set on my jimmy with out problems. i believe they have since retooled them to address those issues. call tim christian and ask where you can buy the new sets, they are made to OER specs., best doors out there, unless you find a set of OEM doors without rust, but good luck on that!
pay attention on the shipping charges, as i almost got hosed on that.
good luck, and let us know how you make out
cant answer your question on the taigate....
SAFETY FIRST
AS usual, off topic
Jim
Old 12-31-2011, 10:20 AM   #25
exploderjim
exploderjim's Avatar
I bought the tailgate and it wasn't to bad. It seemed fairly close to the original but over all looked good and fit well not to mention the work saved not having bang out all the dents and fix the rust.
exploderjim is offline   Reply With Quote
