Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 09-27-2017, 12:21 PM   #1
HotRodfuelhose
Active Member
Smile PTFE AN6 Fuel hose bundle deal
Hi Folks;
This forum has been a big help while building my 1980 C10, this build is what caused this business to be created as I was trying to find fuel line to install my FiTech fuel injection and found it to be a big PITA. I thought I can do better so I got in touch with a ton of manufacturers and got samples. Did a ton of testing and found the best one to go to market. You can check out my Build Thread here.
As a thank you to this Forum as one of the groups who helped me so much through my project I have created a promo code just for you guys. CHEVYTRUCK10
We have on promo right now 20FT of PTFE stainless or Nylon braided line. As well as 8 fittings of your choice - Choose from - Straight, 45, 90, and 180 degree fittings.
Default fitting choice is 2 of each fitting. 2 - straight, 2 45, 2 90, and 2 180 degree AN6 fittings
Perfect for Fitech or Sniper installs. LS swaps, Carbed applications.
Very good chemical resistance compared to rubber lined hose.
114.97 for the AN6
AN8 also available $139.97
Free Shipping on ALL ORDERS
www.hotrodfuelhose.com
Justin
HotRodfuelhose is offline   Reply With Quote
Old 09-27-2017, 01:00 PM   #2
knomadd
knomadd's Avatar
Re: PTFE AN6 Fuel hose bundle deal
Are you going to get black fittings?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 09-27-2017, 02:13 PM   #3
HotRodfuelhose
Active Member
Yes, they are in production and we should see them Mid - Late October in AN6 size. As well we will be getting Blue and Red braided hose in AN6 size.
Old 10-02-2017, 04:50 AM   #4
SIXTY9
Justin,
Do you have kits for the Holley Sniper EFI with return to tank? I am using a 69 Camaro gas tank also by Holley with fuel pump and sender. I am installing the system in a
69 C/10 SWB. If so please Quote.
Thanks,
Wally
SIXTY9 is offline   Reply With Quote
Old 10-02-2017, 10:46 AM   #5
HotRodfuelhose
Active Member
Originally Posted by SIXTY9 View Post
Justin,
Thanks,
Wally
Hey Wally the AN6 bundle for 109.99 should work well for that setup. I run the same on my 1980 with 383 and fitech. The only extra piece you may need is hardline to an6 off the sending unit. I have attached a picture of what that looks like on mine.
Old 10-02-2017, 11:00 AM   #6
SIXTY9
Justin,
Do you have that hardline too?
Old 10-02-2017, 11:02 AM   #7
HotRodfuelhose
Active Member
Justin,
I do not. got mine from summit. The 3/8 size is summit brand and 5/16 was Earls.
Old 10-02-2017, 11:05 AM   #8
SIXTY9
Justine,
Thanks I will get it ordered this weekend.
Thanks for your time.
Wally
Old 10-02-2017, 11:06 AM   #9
HotRodfuelhose
Active Member
Justine,
Wally
Thanks for the support, any other questions let me know.
Old 10-02-2017, 11:13 AM   #10
SIXTY9
Justin,
Would you happen to know the part numbers by chance?
Old 10-02-2017, 11:23 AM   #11
HotRodfuelhose
Active Member
Smile Re: PTFE AN6 Fuel hose bundle deal
Justin,
Part#: EAR-165056ERL
Item: ALUM TUBE ADPT -6 MALE AN TO 5
Part#: SUM-2200077
Item: -6-3/8 MALE HARDTUBE FITTING
Obviously make sure your sending unit is 3/8 feed 5/16 return for these ones.
Old 10-02-2017, 11:27 AM   #12
SIXTY9
Thanks, I will be ordering the EFI system this weekend also. Appreciate you help.
Old 10-02-2017, 11:53 AM   #13
SIXTY9
Kit on order Thanks.
Old 10-02-2017, 11:34 PM   #14
HotRodfuelhose
Active Member
Thanks for your support, I shipped it out today and it was a struggle due to an epic snow storm coming down right now.
If anyone else is looking for the Black nylon braided PTFE hose in the AN6 size I currently only have 2 bundles left.
Justin
Old 10-03-2017, 05:36 AM   #15
SIXTY9
Thanks hope it wasn't too bad. It will be awhile before I get installed. I will be breaking in engine with carburetor, after that I will send you some pictutes.
Wally
Old 10-09-2017, 08:53 PM   #16
HotRodfuelhose
Active Member
Wally
Look forward too it.
Old 10-16-2017, 12:10 AM   #17
HotRodfuelhose
Active Member
AN6 straight fittings are currently SOLD OUT. We will be getting more but without the straight fittings the bundle is unavailable as well.
If you would like a Bundle with 45/90/180 degree fittings we can still make that work but you must message directly as the website will not process the order.
AN8 is still available
Thanks.
Old 10-16-2017, 08:30 PM   #18
hotrodsinner
hotrodsinner's Avatar
When will more straights be available?
hotrodsinner is offline   Reply With Quote
Old 10-16-2017, 08:32 PM   #19
HotRodfuelhose
Active Member
Shortly. I actually have 2 left as another customer chose to go with 45s instead. I can make one bundle work.
Let me know.
Old 10-19-2017, 11:01 PM   #20
HotRodfuelhose
Active Member
Black fittings in AN6 are now in stock.
Black hose will be restocked next week.
Black fittings with stainless hose is currently available.
Old 10-20-2017, 12:17 AM   #21
hotrodsinner
Pm sent
Old 10-20-2017, 12:29 AM   #22
HotRodfuelhose
Active Member
Originally Posted by hotrodsinner View Post
Pm sent
Got it and replied, have a great weekend.
Old 10-30-2017, 08:59 PM   #23
HotRodfuelhose
Active Member
Hi my friend. The black bundles are now available.
https://hotrodfuelhose.com/collectio...-fittings-save
braided, fuel hose, nylon hose, ptfe, stainless hose
