Old 12-17-2017, 05:39 PM   #1
T2vigil
T2vigil's Avatar
Track bar mounting locations
When did Chevy make the change from pumpkin mounted to axle mounted track bars? Or visa versa. The rear end of my 64 axle mounted track bar is shot. I have a donor truck (64?) with a pumpkin mount. I have the ability to remove and weld the axle mount. Is there any advantage to which mount is better.
T2vigil is offline   Reply With Quote
Old 12-17-2017, 06:39 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Track bar mounting locations
The longer the bar the better. Especially on lowered trucks. My Porterbuilt bar is outside and to rear of stock driver side to the lower trailing arm mount. I had original mount on far passenger axle tube.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 12-18-2017, 12:39 AM   #3
Captainfab
60-66 Nut
The '60-'62 and '63-'64 had the longer panhard bar with the mounting bracket welded to the passenger side axle tube. The '65-'72's had the boss with the stud on the center section of the differential.
Old 12-18-2017, 10:36 PM   #4
rvrfoot
Mine is a 66.Name:  DSCN0911.jpg
rvrfoot is offline   Reply With Quote
Old 12-18-2017, 11:45 PM   #5
Cris
1963 Track bar mount.
Cris is offline   Reply With Quote
