What type of engine do I have?
Bought a 71 c10 that came with a 350. Was told by the owner that it’s not the original engine but does not know where the engine came from. It seems to be leaking oil now and need a few gaskets replaced. Unfortunately, I’m having a hard time getting them as I don’t know what type or year of 350 I have?
Anyone have an idea on how to find this info out? |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: What type of engine do I have?
Behind the left head and just above the bell housing is the block casting number. Use a small wire brush and a flashlight and you can usually clean it up to read it. The engine code stamping is located directly in front of the right head on the block deck surface. That stamp sometimes will be gone in the case the block deck has machined in the past. Read this; http://www.nastyz28.com/sbchevy/sblock.html
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: Feb 2012
Post those numbers and you 'll get a correct answer in about 5 minutes !
