Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 09-15-2022, 06:23 PM   #1
Zac72blazer
Active Member
ISO Blazer Jimmy spare tire carrier carriage bolt
ISO Blazer Jimmy spare tire carrier carriage bolt...and nut
Zac72blazer is offline
Old 09-15-2022, 09:21 PM   #2
smupser
Active Member
Re: ISO Blazer Jimmy spare tire carrier carriage bolt
I’m just curious and this question may be ignorant as I’m not completely sure, I have a couple of carriers that I’m restoring, I have the carriers and oversized washers, but as far as the bolts go, isn’t it almost exactly like a carriage both readily available at any hardware store?
smupser is offline
Old 09-15-2022, 09:29 PM   #3
Zac72blazer
Active Member
Ya probably pretty close.
Old 09-15-2022, 09:32 PM   #4
franken
https://www.google.com/search?q=gm+3991023+bolt
franken is offline
Old 09-15-2022, 09:36 PM   #5
Zac72blazer
Active Member
WOW 👏 what a genius I never thought about using Google...thanks
Old 09-16-2022, 12:59 AM   #6
franken
It's easier, though less productive, to ask, then wait hours, than do a search that returns answers in a second or check a hardware store, where nuts and bolts live.
franken is offline
Old 09-16-2022, 02:53 PM   #7
Zac72blazer
Active Member
Maybe....just Maybe I already did a search. 🤔
Old 09-16-2022, 03:25 PM   #8
71K5Randy
71K5Randy's Avatar
69-72 is a 7/16 fine thread carriage bolt that is over 6” long. Hard to find that as common hardware, if they exist at all. GM used a lug nut to fasten the wheel, hence the 7/16 fine thread bolt.
73+ changed to a 1/2 coarse thread and z-bar wing nut, so common carriage bolts are easy to come by in that thread.
The washers were identical across years.
Hope that helps.
71 K5 CST Blazer 350
70 Suburban 350
71 Chevelle SS 454
69 Olds 442 454 (yes, Chevy power!)
68 Camaro RS 327
66 Chevelle SS 396
Members I have met: 62cdan, 60case, daddymoo2, aotte1, 70shortfleet, countr, Cowboy#40, chevy71super, davischevy
71K5Randy is offline
Old 09-16-2022, 03:53 PM   #9
Zac72blazer
Active Member
Hope that helps.
Thanks that helps some., but I need an example to measure.
Closed Thread
