Old 02-01-2018, 08:21 PM   #1
Jferrante
Jferrante's Avatar
Project 66: LS and Frame on the Ground
Well I am back with my 3rd 60-66. Cant stay away. This time I am building what I always planned on doing previously; LS swap (well LQ4) and full step notch, dropmember and power steering and power disc brakes. Goal is laying frame.
The truck I bought is from the south and was an incomplete project that has 80% of what I would have been buying already so I really hit the jackpot. Very little to no rot, only small section of drivers floor but I am not concerned about that for now.
Originally was looking at a few trucks with 350s that I would have had to try to sell but ended up finding this one that has a 6.0 out of a 2003 pickup; so no aluminum block but I liked the idea of a 6.0 and it is an LS variant.
I wasnt planning on doing much to the motor but since it is coming out I think I am going to reseal it, get the injectors tested and maybe a few maintenance items - I am new to these engines so I am open on ideas on how to spend money wisely on it.
Here she is waiting to be loaded and then unloaded today at my house.. buddy and I had the bed, hood and front clip off in no time. Planning on pulling the cab this weekend and getting the motor out.
Jferrante is offline   Reply With Quote
Old 02-01-2018, 08:46 PM   #2
Rusty63
Rusty63's Avatar
Re: Project 66: LS and Frame on the Ground
Nice,you don't waste any time huh! even rear tank already...nice score..
Rusty63 is offline   Reply With Quote
Old 02-01-2018, 08:46 PM   #3
hewittca
hewittca's Avatar
Looks like a cool little truck to start with. That is ambitious of you to have it torn down already! I think I would have cruised it around a bit before I started on it.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 02-01-2018, 10:26 PM   #4
Jferrante
Jferrante's Avatar
Thanks guys, if I dont get moving immediately it won't get done - and yes rear tank is another bonus. This truck actually came with coilovers in the rear so I will be selling them to anyone who is interested just send me a note.
and a ****ty pic but can see how they bolt up.
Old 02-02-2018, 09:15 AM   #5
timmytimm3
Nice truck to start with! Subscribed
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 02-03-2018, 04:29 PM   #6
Jferrante
Jferrante's Avatar
Goal for last night and today was to get some jigs made up and the cab off. Did this all solo, not the best craftsmanship but it did the job.
Next is going to be pulling the motor and trans and getting the frame cleaned up ready for some cutting and notching. Also will be going through the motor, not sure how deep yet maybe just remove the heads and check the gaskets.
Old 02-03-2018, 05:39 PM   #7
slimjim66
cool build man, ill follow along. run a leak down test on the motor before you dive into it, you might be surprised with the results, i bought a LQ4 for my '66 and was almost certain i would be doing a full tear down, especially with 200+ miles on the motor. but after my leak down test came back with 8-10% difference i left it how it was.
slimjim66 is offline   Reply With Quote
Old 02-03-2018, 07:19 PM   #8
Jferrante
Jferrante's Avatar
thought about doing a leak down as well and is probably the right approach. It ran fine for the 15 mins I had it before I started ripping it apart. Will start pulling plugs and coils tomorrow.
Old 02-04-2018, 07:01 PM   #9
Jferrante
Jferrante's Avatar
Engine up and out. Going to do water pump/gaskets, timing chain cover clean up and gasket and probably heads off as well.
Old 02-05-2018, 09:08 AM   #10
Bennett68C10
Bennett68C10's Avatar
Nice looking project, can't wait to see what you do with it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-07-2018, 08:53 PM   #11
Jferrante
Jferrante's Avatar
Thanks!
Waiting on a few gaskets for the motor but keeping the momentum going. Removed the fuel lines from the frame so its ready for a bit of blasting. Going to be ordering the choppin block setup early next week, Travis has been great at answering questions.
In the meantime I got my transmission solenoids, filter and gasket so I cleaned up the tranny a bit and got the new bits installed.
Still need to clean up the bell housing but its better than it was. This is no show truck but trying to clean up where I can.
Old 02-08-2018, 08:39 PM   #12
Jferrante
Jferrante's Avatar
Started to pull the driver head tonight and found a nice little crack - had a bad feeling about it. Seller actually was really cool and refunded me some money for this.
The question now is do I upgrade or just look for a replacement block for 3-400 and keep moving on? Really dont want to spend 3k on a motor but I am tempted.
Old 02-08-2018, 10:43 PM   #13
slimjim66
Oh no, that’s to bad. I remember few years ago you could buy a reconditioned LQ4 block from summit for like $350 or something. I check every now and then and it says out of stock still. Good thing you found the crack though. You could always buy a LSX block if 2000hp is in your near future lol. Good luck on your search for a new one.
Old 02-08-2018, 10:52 PM   #14
Jferrante
Jferrante's Avatar
Yea could be worse...looks like I can get a LQ4 for less than 1k which isn't bad.
Old 02-09-2018, 09:21 AM   #15
Bennett68C10
Nice choice going with Choppin Block and going through Travis to purchase it. That's where I got my last one from and his customer service is second to none.
Keith
66 Suburban
IG: bennett68c10
Old 02-09-2018, 12:08 PM   #16
Jferrante
Jferrante's Avatar
Yea great guy to deal with.
Motor Update: I found a 6.0 only an hour and a half away that I am picking up tomorrow morning.
Old 02-09-2018, 02:10 PM   #17
TimE
Hey Y'all!!
TimE's Avatar
Glad you found another 6.0 close by.
Any time the heads are pulled on an older LS motor, I would suggest changing the lifter trays. Just cheap insurance while you're that far in...
BTW, love the blue patina. That has always been my favorite color on that body style.
Good luck!!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-13-2018, 12:10 PM   #18
Jferrante
Jferrante's Avatar
Placed my order with Travis yesterday so hopefully all those goodies will be here in the next 2 weeks or so. In the meantime I am going to paint the frame and get rid of my front cross member and power steering setup. Going to post these in classifieds but probably need to sell to someone local.
Ordered new lifters, push rods and lifter trays for the 6.0 so crossing my fingers the motor will be assembled and ready to go this weekend.
Old 02-13-2018, 09:37 PM   #19
Notch1988
Notch1988's Avatar
Keep the updates coming.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 02-13-2018, 10:44 PM   #20
Jferrante
Jferrante's Avatar
Will do - need some help and pics on what to do with the steelies - I have white patina'd hubcaps and I was debating on painting the wheels white or body color blue...the problem is the skinny white wall, not sure how it will look either way. Other option is new wide white walls but these tires are new...
Old 02-17-2018, 05:46 PM   #21
Jferrante
Jferrante's Avatar
Knocked a few things out yesterday and today. Got the lifters and new lifter trays in as well as the head gaskets and heads back on. The rocker arm mounts were cross threaded so I didnt get those back in I will tap them tomorrow and finish the heads.
Pulled the front spindles off and gave them a fresh coat of paint, nothing crazy but wanted them cleaned up.
Looking for a high hump trans tunnel and firewall piece so I can get that all finished up as well because once I finish the frame I want to get everything put back together asap.
Old 02-19-2018, 01:19 PM   #22
Jferrante
Jferrante's Avatar
Have some time before the frame pieces come in so I decided to paint the LQ4. Nothing crazy but I think it looks great. Unfortunately these motors get covered up pretty quick once the coils and accessories go on.
Before:
After:
Old 02-19-2018, 02:54 PM   #23
Notch1988
Notch1988's Avatar
Surprised you didn't toss a cam in there.
What head gaskets did you go with?
Link to my build:
My GMC Project
Old 02-19-2018, 03:27 PM   #24
Jferrante
Jferrante's Avatar
Could have done a lot of things but keeping the engine piece of the build as budget friendly as possible. I used fel-pro gaskets
Old 02-19-2018, 08:24 PM   #25
Jferrante
Jferrante's Avatar
cleaned up the intake and got the water pump and tensioner mounted. Next is cleaning power steering bracket.
