Old 07-02-2018, 01:57 PM   #1
UTSA
UTSA's Avatar
Hard to steer when breaking
Right after I rebuilt my front suspension with new power steering and power brakes (Drum/Drum) I’ve noticed that it’s hard to steer my truck when I’m coming to a stop or slowing down. I did not do hydroboost so that is out of the question.
For example: going 30mph and when I need to turn into a driveway, I’ll start slowing down and when I’m at a decent turning speed and still have the foot on the brake pedal, the steering wheel will be really really hard to turn. As soon as I let go of the brake, it turns smoothly.
I have a feeling it has something to do with the brake pads in the front drums or maybe I let something loose on the suspension...what do y’all think?
1965 C10 350 combo
UTSA is offline   Reply With Quote
Old 07-02-2018, 03:02 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Hard to steer when breaking
I'm voting on something loose in the suspension/bearings, after that brake pads/drums. I'd get it up on safety jacks and check for "any" play in the steering (box or links) then your wheel bearings, brake pads, drums.
Besides it will give you confidence.
Old 07-02-2018, 04:49 PM   #3
padresag
does it pull to one way at all when you apply the brakes. it may be a brake hose giving you a problem
ron
padresag is offline   Reply With Quote
Old 07-03-2018, 10:57 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Are you running hydroboost? Its a semi common symptom when first setup.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-03-2018, 06:17 PM   #5
UTSA
UTSA's Avatar
I took a look under and my center link is too close to the subframe that is right under the enfine. I’ll take a closer look today and see if that is what has been running and keep y’all updated.
If it is that, then I have a feeling the wheels travel back jusr slightly so that the center link touches the subframe and makes steering difficult. Because as soon as I let go, it’s back to normall.
1965 C10 350 combo
Old 07-03-2018, 06:18 PM   #6
UTSA
UTSA's Avatar
ron
It does not pull any direction. I thought of this but that would be if one side of my drums is tighter than the other. I do have my rear brakes lock up but that was expected...i have no weight in the back and i need to loosen them up jusr a bit.
1965 C10 350 combo
Old 07-03-2018, 08:23 PM   #7
padresag
brake hose can cause problem on 1 side and on the side that is problematic. if the hose becomes soft on the inside and collapses
ron
most of those centre links are close to begin with
Old 07-08-2018, 05:49 PM   #8
karlbenz
make sure them rear drums are adjusted and working good. I had that issue when I first got mine
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
karlbenz is offline   Reply With Quote
Old 07-10-2018, 03:00 PM   #9
modes
"as soon as I let of the brake pedal" as in hit the gas again? Then I would say the steering pump is turning to slow at idle (on the brakes) to assist the turning properly.
Adam
modes is offline   Reply With Quote
Old 07-10-2018, 05:39 PM   #10
damnyankee36
damnyankee36's Avatar
Adam
X2. When you turn the wheel with the brakes off the wheels are free to turn on the spindles. With the brakes on the tires scrub the pavement putting a load on the power steering pump.
damnyankee36 is offline   Reply With Quote
Old 07-14-2018, 10:00 PM   #11
UTSA
UTSA's Avatar
Update, there’s no suspension linkage rubbing anywhere.
I did notice the other day, leaving through a steep driveway, it seemed to also be stiff to move the steering wheel.
So my next thing to do, is to drive the truck up a curb or something where the wheels will all be different elevations. Then crawl under while someone tries to steer it and see what is happening.
Any other theories y’all have jusr send them my way.
1965 C10 350 combo
Old 07-15-2018, 05:53 PM   #12
bama63
bama63's Avatar
ball joint binding?
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
booster, drum, power, steering, suspension
