Old 01-20-2014, 02:05 PM   #1
lucky_7
lucky_7's Avatar
Need help with Exhaust!
Hey guys,
I need a little help installing exhaust for my 98 5.7 ext cab sierra. Currently Im looking at a flowmaster super 50 series , 2.25'' dual in/3.00'' center out with a turn down. I just need to know the stock exhaust size coming from the cats so can buy the right adapters. Later I plan on doing some engine mods and going with headers and true duels with and x pipe and 2 flowmasters.
lucky_7 is offline   Reply With Quote
Old 01-22-2014, 03:53 PM   #2
TheBlueBomber
TheBlueBomber's Avatar
Re: Need help with Exhaust!
I believe stock exhaust is 2 1/4" all the way through. That was what was on my '96 when I bought it.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 01-22-2014, 06:25 PM   #3
lucky_7
lucky_7's Avatar
thanks, guess i could use my calipers to measure the outside and subtract the wall thickness......duh
Old 01-23-2014, 10:49 PM   #4
country29
my 97 ecsb Z71, right at the dual inlets of the stock muffler each pipe is 1 7/8", i'm sure its same up to cats. 2" id to 2.25" adaptor will leave a small gap to fill with the welder on the original pipe.
country29 is offline   Reply With Quote
Old 01-23-2014, 11:42 PM   #5
lucky_7
lucky_7's Avatar
Yup, I measured them earlier and they are 1 7/8", from the muffler to the cats and I'm sure they are the same to the manifolds.
Old 01-24-2014, 01:22 AM   #6
TheBlueBomber
Thank God you didn't listen to me then haha.
Austin
Old 01-28-2014, 03:50 PM   #7
lucky_7
lucky_7's Avatar
hehe, ya, but thanks for trying bluebomber
Old 01-29-2014, 02:21 PM   #8
TheBlueBomber
My manager always says... "It's not about if you win or lose, It's how you prepare for the game".....
I guess I made him proud on this one.
Austin
Old 06-09-2014, 06:17 PM   #9
lucky_7
lucky_7's Avatar
Anybody know of a store bought y collector that will fit on the pipes behind the cats?
Old 06-09-2014, 06:38 PM   #10
Blue97
Blue97's Avatar
You will probably have to have it made at the muffler shop of choice...Ive looked for a y pipe... If your going to change it later why not just wait and do it then?
I went and replaced the front pipes with a flowmaster kit and high flow cats, now im adding this. http://www.summitracing.com/parts/wlk-54020 and two Aerochambers dumped over the rear axle...........
Im running a DI/SO flowmaster 50 series now.... Me no likey
Blue97 is offline   Reply With Quote
Old 06-09-2014, 06:39 PM   #11
lucky_7
lucky_7's Avatar
Thanks blue...
Old 06-12-2014, 11:07 AM   #12
lucky_7
lucky_7's Avatar
Does anybody now if I can completely remove the cats from a 97 5.7 liter, I can only see one set of o2 sensors in front of the cats, and I have been told that its okay like that. But Ive also been told the truck will still run a little rich with the cats removed?
Old 06-12-2014, 12:18 PM   #13
1997z71
On my 97,I went with the 50 series then 4" chrome tips out the back,way too loud for a stock engine. Have since added baffles in the 4" tips,now it sounds good. Didn't notice any change in performance or mpg.
1997z71 is offline   Reply With Quote
Old 06-12-2014, 12:23 PM   #14
lucky_7
lucky_7's Avatar
where were your o2 sensors at before, and did you remove the cats?
Old 06-12-2014, 12:29 PM   #15
1997z71
I left them on. I wouldn't remove them unless they're going bad.
Old 06-12-2014, 03:11 PM   #16
lucky_7
lucky_7's Avatar
what about high flow cats? truck has 120k on it now and since im already here i might as well replace them right...
Old 06-12-2014, 03:21 PM   #17
Blue97
Blue97's Avatar
Yes........ I installed the Flowmaster kit and have seen improvements in sound and HP, Not a lot but its noticeable.
Old 06-12-2014, 03:40 PM   #18
lucky_7
lucky_7's Avatar
thanks guys,
Well i found a 50 series delta flow the other day in the junk yard, paid 35 dollars for it, it 3''in/3''out, so im not ever sure in i can use it without having a custom y pipe made to come from the cats to the muffler.
If I were to buy a high flow cat at 3''in/out, I could just have them y it at the bottom of the drop pipes and tuck the cat nicely, then I could (weld this myself) extend 3'' pipe straight back to the flow and put a turn down on it....
I would get both a new cat, and a new muffler, for around......let see
100.26 +tax for the cat
35.00 for the muffler
maybe 100. to install
thats only 235.+/- for a complete system...
Old 06-18-2014, 11:38 AM   #19
lucky_7
lucky_7's Avatar
Anybody have a diagram of the o2 sensor locations on my truck?
Old 06-18-2014, 01:28 PM   #20
Blue97
Blue97's Avatar
I'm at work but let me see what I have on the comp at home. I just did all 4 of mine . Pretty simple , just a plug and play deal.
Old 06-18-2014, 05:25 PM   #21
lucky_7
lucky_7's Avatar
Okay thanks, Ive looked for them behind the cats, and i cant see them anywhere, just one on each down pipe...
Old 06-18-2014, 05:43 PM   #22
Blue97
Blue97's Avatar
Hope this helps.
Old 06-18-2014, 07:53 PM   #23
lucky_7
lucky_7's Avatar
Thanks, I'll go look at it now
Old 06-18-2014, 10:13 PM   #24
lucky_7
lucky_7's Avatar
Well I found them, I have four, , so no high flow cats for me, I'll just put on a nice flowmaster with aggressive sound to overcome the restriction from the cats....
Old 06-18-2014, 10:18 PM   #25
lucky_7
lucky_7's Avatar
What's a good aggressive sounding flow for the 5.7 Liters?
I did a little looking, maybe a super 40?
