F E Drive
Has anyone used this water pump?
What H balancer does it require? Holley Performance 20-185 Mid-Mount LS Accessory Drive System Kit Holley's Mid-Mount complete accessory system has all accessories pulled in tighter than other accessory drives. Among the many swap, friendly features is the bracket-less assembly that actually mounts all accessories to the water pump directly.olley Performance 20-185 Mid-Mount LS Accessory Drive System Kit
Re: F E Drive
it comes with the crank pulley / balancer for the crank.
you have to use their pulley, I don't think it matches any of the corvette/Fbody/Truck balancers exactly. If you want one with a tru harmonic balancer, the kit 200-180 comes with the ATI balancer instead of the stock type GM pulley
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
BMW & ASE Master Certified
Re: F E Drive
I wouldn't buy that kit... if the waterpump fails one day, you'll be stranded and have to order the pump and hope they have them instock/not discontinued.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Re: F E Drive
Good point!
So the water pump is a "Holley" brand not off the shelf not like the early V8 riser castings with the 6 cylinder water pump
![]() Join Date: Mar 2011
Re: F E Drive
Solid, now your going back to "the day", haven't thought about those in years...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Re: F E Drive
Maybe, probably need to see if that pump is a factory part to make sure.
