Old 09-24-2018, 10:39 PM   #1
mikebGMC70
Rear end swap
Probably a silly question but here it goes.
I have a 70 8 lug wide rear end and I’m switching to trailing arms. The rear end I got is the shorter one. Will the early narrow rear fit or do I have to stick with the wide axle?
Going from a Dana to an Eaten. Don’t judge.
mikebGMC70 is offline   Reply With Quote
Old 09-25-2018, 12:02 AM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Rear end swap
You currently have leaf springs? If so, it shouldn't matter. You will have to build a mount for your coil spring.
low'n slow is offline   Reply With Quote
Old 09-25-2018, 12:08 AM   #3
mikebGMC70
My current setup is leafs and the rear end I bought was for trailing arms, it is just narrower than my current rear end.
Old 09-25-2018, 12:18 AM   #4
Coley
Coley's Avatar
Re: Rear end swap
The diff housing will need to have a connection boss for the panhard rod, which controls and helps stabilize the axle action.
Google a few pics of the pan hard rod arrangement and this will make sense.
All good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 09-25-2018, 12:38 AM   #5
mikebGMC70
Re: Rear end swap
I’m using the CPP Panhard that connects the trailing arm to the frame.
