01-20-2019, 05:37 PM | #1 |
Brake line junction block - 1969 4X4 K5 Blazer
Any one know where to source a brass junction block for a 4X4 that goes on the inside of the driver's side inside the frame? The front brake hose goes into it through the frame, and there are two brake lines that go in either side. There is a hollow 5/8 headed bolt that threads into the brake hose. Thanks for any help. Rick
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
01-20-2019, 10:08 PM | #2 |
Re: Brake line junction block - 1969 4X4 K5 Blazer
Are you looking for the proportioning valve?
-Bruce 1971 K5 Blazer 4WD |
01-20-2019, 11:04 PM | #3 |
No, it is a junction block on the inside of the frame.
01-20-2019, 11:26 PM | #4 |
Well now I am curious!!
01-20-2019, 11:32 PM | #5 |
I'll try to remember to take a couple of photos tomorrow.
01-21-2019, 12:18 AM | #6 |
I think there is one on the left and right if I remember correctly. I believe inline tube or LMC would have them.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
01-21-2019, 08:15 AM | #7 |
Didn't see the one I need on inline's site. Thanks though.
01-21-2019, 08:49 AM | #8 |
I have some stuff I took off my 70 4x4 4 wheel drum power brake system. Think it might be in that stuff?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
01-21-2019, 03:41 PM | #9 |
This one is specific to the driver's side. I believe I may have got it to stop seeping. Took it apart again and replaced the copper washers again. Although the hollow bolt threads into the brake hose, the face of the hose end also abuts a washer (banjo fitting). I took a couple of photos. If you have one, hold onto it.
01-21-2019, 04:46 PM | #10 |
I ordered all new prebent lines for mine i have to check if it’s in the box with them.
01-21-2019, 05:12 PM | #11 |
Interesting; is is just a connection point or does it have another purpose? Gonna have to go see if I have one now!
01-21-2019, 08:11 PM | #12 |
Yup. I got one of them somewhere. I am not using it. It's in a bucket somewhere in the garage.
02-02-2019, 06:40 PM | #13 |
So to bring this back up my lines do not have a junctuon block where yours is shown at the soft brake line connection. I do have a junction but it is right next to the front crossmember and not bolted to anything. One like shoots back to the driver soft line and one line goes across the crossmember to the passenger soft line. This is how my old lines were and how the new lines hook up. I think this is stock but could be wrong.
02-02-2019, 06:41 PM | #14 |
Here’s reference I used for my ORD steering support. It shows the junction block just like I have.
http://67-72chevytrucks.com/vboard/s...d.php?t=694692
02-02-2019, 08:05 PM | #15 | |
02-02-2019, 09:12 PM | #16 |
You’re probably right. I didn’t think about the spread in years.
02-02-2019, 09:30 PM | #17 |
My 70 K10 short bed fleet was the same as the 69 Blazer. Can't remember the 71 Blazer but it had front disc brakes (first year for discs) so that was probably the change?
