02-25-2019, 09:00 PM | #1 |
Speedometer Driven Gear
I’m asking to see if this can be pulled out while the transmission is still on the truck? I have a SM318 with 3 on the tree. I’m not going to try I was just curious. Thanks!!
02-25-2019, 09:12 PM | #2 |
Re: Speedometer Driven Gear
Of course!
The speedo bullet slides right out after you remove the clip and bolt. |
02-25-2019, 09:13 PM | #3 |
Yes it can, just make sure you park at a steep angle, or jack up the rear end. That makes all the gear oil go to the front of the trans so you don't spill any out. When I first did it with my 3 speed OD, (same trans as you, but with a Borg Warner overdrive unit in place of the tailshaft) I did not have the back end up high enough, so some gear oil spilled out. The second time, I parked on a small hill and didn't have any gear oil spill out.
Also, if you are just swapping the driven gear, you can pull the speedo bullet out without disconnecting the speedo cable. Makes it quicker and easier. If you do it this way, put the driven gear back into the speedo bullet before you put it back in the trans. Hope that helps!
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-25-2019, 09:24 PM | #4 |
Thanks for the quick responses!! I need to replace the gear and I’ve never messed around with a transmission before so I’m a little leery. Thanks so much for helping out a rookie!!
