06-01-2019, 01:47 PM | #1 |
1970 C20 bench seat question
I have a 70 C 20. The stock bench has seen better days, bad foam and broken springs.
I found a bench seat from a 75 C10. Will this work for my truck? Are there any modifications that will need to be done to make it fit? |
06-01-2019, 10:04 PM | #2 |
10/30/19
Re: 1970 C20 bench seat question
I’m thinking that it won’t bolt up correctly. You can always measure the seat frames to verify.
06-02-2019, 12:05 AM | #3 |
Get a New foam Kit and Seat Upholstery it will be good as new.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
06-02-2019, 11:34 AM | #4 |
Moderator
It won’t bolt right up. Seat frames and mounting tracks are different. I’m sure you could “make it work” by drilling new holes and/or modifying mounts. Most any older seat you find will have busted springs on the sides which cause you to lean outwards and be uncomfortable. Repair the one you have is what I’d do.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
06-03-2019, 09:54 AM | #5 | |
06-03-2019, 10:13 PM | #6 |
A local Auto Upholstery shop can fix your springs for you.
Tags |
bench seat, c20 |
