08-28-2019, 09:02 PM | #1 |
Whats it called????
Can anyone tell me what the plug (for a better word) is called that goes on the terminal of a fuel sending unit. It pushes down on the terminal like it has threads on it. I am stuck.
John
Big Blue ( John ) 79 Chevy Pick up.....My Dailey STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in. |
08-28-2019, 09:45 PM | #2 |
Re: Whats it called????
The connection wire for the gas tank sending unit. So you can read how much gas is in the tank.
08-28-2019, 10:08 PM | #3 |
Thanks Ziegelsteinfaust, maybe I said it all wrong. What I was asking is what is the wire plug called that you push down on the pin to make it read the fuel level. After doing some research I think it is called a Single Contact Molded Connector (90 Degree Single Contact Female Molded Connector). If it is then I just ordered 2 of them.
Thanks for responding, John
08-28-2019, 10:08 PM | #4 |
I'd call it a connector, push-on electrical connector
08-28-2019, 10:10 PM | #5 |
Thanks special-K, I was typing as you responded. see post above, I think I have it now, As I said I just ordered 2 of them. Thanks Again, John
