10-21-2019, 04:01 PM | #1 |
Ring and Pinion Install Cost
My pinion seal is leaking pretty badly and my bearings feel worn so I ordered a new R&P and install kit to get installed. This is not something I want to do myself and the shop I generally have work done quoted between $600-$800 for labor which I thought was a bit high. How much should this cost? Also, what kind of shop do I need to do a google search on to find a place to do this? Thanks.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
10-21-2019, 07:10 PM | #2 |
Re: Ring and Pinion Install Cost
I never install customer parts! They either buy mine or get so high of a price that they go somewhere else!
10-21-2019, 07:19 PM | #3 |
call all of them .
google "driveline repair durham NC"
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-21-2019, 07:42 PM | #4 |
If I setup a diff out of the car I charge $300 for a rear. $400 for a front. $100 more for each in the car. And that is my "not a professional shop" rate. Figure it is a 4-6 hour job if they are doing it right.
10-21-2019, 09:37 PM | #5 |
My guy locally does $350 an axle for pretty much anything.
10-22-2019, 12:20 PM | #6 |
I paid $800 to have mine done about 8 yrs ago. So I think thats about right.
10-22-2019, 01:20 PM | #7 |
Seems that anything that involves opening up and removing/installing a diff carrier and R/P starts at $1000 and goes up from there. That's parts and labor.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
